查看: 899|回复: 4
[求助] [求助]:各位:帮我看看这段求交点座标的程序错在哪里(帮我指出来)
发表于 2004-5-18 21:43:13 | 显示全部楼层 |阅读模式
(DEFUN C:INT_L ( )
       (SETQ OBJ1 (ENTSEL "\nSelect first line : ")
               OBJ2 (ENTSEL "\nSelect second line : "))
       (IF (OR (= OBJ1 NIL) (= OBJ2 NIL))
               (PRINC "\nNone object select") (PRONG
               (SETQ ENT1 (ENTGET (CAR OBJ1)) ENT2 (ENTGET (CAR OBJ2)))
               (IF (OR (/= (CDR (ASSOC 0 ENT1)) "LINE")
                            (/= CDR (ASSOC 0 ENT2)) "LINE"))
                       (PRINC "\nObject type is not a Line") (PROGN
                       (SETQ PT1 (CDR (ASSOC 10 ENT1)) PT2 (CDR (ASSOC 11 ENT1))
                               PT3 (CDR (ASSOC 10 ENT2) PT4 (CDR (ASSOC 11 ENT2)))
                       (SETQ PT_INT (INTERS PT1 PT2 PT3 PT4 NIL))
                       (IF (= PT_NIT NIL)
                               (PRINC "\nNone Intersection Point")
                               (COMMAND "LINE" PT_INT)
       (PRINC))
发表于 2004-5-18 23:15:45 | 显示全部楼层
progn写成prong了
都少了括号应为
(/= (CDR (ASSOC 0 ENT2) ) "LINE"))
你写的程序也太乱了
写的规范一点就不会有这些错误了
我修改以后如下
[php]
(DEFUN C:INT_L ( )
    (progn
              (/= (CDR (ASSOC 0 ENT2)) "LINE"))
        (PROGN
                PT3 (CDR (ASSOC 10 ENT2))
          (IF (= PT_INT nil)
  (PRINC)
[/php]
 楼主| 发表于 2004-5-19 08:41:54 | 显示全部楼层
楼上兄弟上面程序怎么求不出交点?
发表于 2004-5-19 08:49:50 | 显示全部楼层
(IF (= PT_NIT nil)
这句也错了,是PT_INT不是T_NIT
这个我到没有看出来!!
上面也已经改过来了
 楼主| 发表于 2004-5-19 16:17:24 | 显示全部楼层
楼上兄台谢了,我是初学者,以后要多多指教了
GMT+8, 2026-11-4 20:48 , Processed in 0.417991 second(s), 40 queries , Gzip On.
