查看: 3126|回复: 5
[推荐]:修改任何文字(包括属性块、有名无名块)
发表于 2009-5-25 13:09:47 | 显示全部楼层 |阅读模式
转发一好用程序,可修改任何文字,唯独不能修改尺寸文字,望原创作者或各位高手能修改一下。
LISP:
;自定义UnDo范围
(defun EF:UNDOBegin ()
                (setvar "CMDECHO" 0 )
                (command "_.undo" "_group")
                (princ)
) ;end defun
(defun EF:UNDOEnd()
                (setvar "CMDECHO" 0)
                (command "_.undo" "_end")
                (princ)
) ;end defun
(defun c:tt( / dcl_id1 oba ob1 obn obt ptn otxt txt sty styno lay cyn layno hig wid ang col cnu etlst style layer)
        (graphscr)
        (EF:UNDOBegin)
        (setq olderr *error*)
        (defun *error*(msg)
                (princ "\n*ERROR*...")
                (princ msg)
                (princ)
        );end defun error.
        (defun set_color ( conm / costr )
                        (defun map_color ( ckey mno )
                                (start_image ckey)
                                (fill_image 0 0 (DimX_tile ckey) (DimY_tile ckey) mno)
                                (end_image)
                        ) ;end defun
                        (cond        ((= 0 conm)(setq costr "Byblock"))
                                ((= 1 conm)(setq costr "Red"))
                                ((= 2 conm)(setq costr "Yellow"))
                                ((= 3 conm)(setq costr "Green"))
                                ((= 4 conm)(setq costr "Cyan"))
                                ((= 5 conm)(setq costr "Bule"))
                                ((= 6 conm)(setq costr "Magenta"))
                                ((= 7 conm)(setq costr "color"))
                                ((= 256 conm)(setq costr "Bylayer"))
                                ( t (setq costr ""))
                        ) ;end cond
                (cond ((= 0 col)        (map_color "col" 7))
                        ((= 256 col)(map_color "col" (cdr (assoc 62 (tblsearch "layer" lay)))))
                        (t (map_color "col" conm))
                ) ;end cond
                (if (= 256 conm)
                        (set_tile "cnu" (strcat "<" (itoa (cdr (assoc 62 (tblsearch "layer" lay)))) ">" costr))
                        (set_tile "cnu" (strcat "<" (itoa conm) ">" costr))
                ) ;end if
         ) ;end set_color
        (defun        map_keylist( key keylst );set popuplist
                (start_list key)
                (mapcar 'add_list keylst)
                (end_list)
        );end map
        (defun layer_get_all( / lay layer layname)
                (setq layer nil                                ;;All layer
                                lay (tblnext "LAYER" T)
                (while (/= lay nil)
                        (setq layname        (cdr (assoc 2 lay))
                                        layer (cons layname layer))
                        (setq lay (tblnext "LAYER"))
                (setq layer (ACAD_Strlsort layer))
                layer ;all layer.
        ) ;end defun
        (defun style_get_all( / sty style sty_list)
                (setq sty_list nil sty (tblnext "style" t))
                (setq        style (cdr (assoc 2 sty)))
                (while style
                        (if (/= "" style)(setq sty_list (append sty_list (list style))))
                        (setq sty (tblnext "style"))
                );end while]
                (setq sty_list (ACAD_Strlsort sty_list))
                sty_list
         );end defun
        (defun set_error(str)
                (set_tile "error" str)
         ) ;end defun
        (defun sub_mtext ( color entlist / ei newlist)
                (setq ei 0 newlist nil)
                (while        (< ei (length entlist))
                        (setq newlist (cons (nth ei entlist) newlist))
                        (if (= 8 (car (nth ei entlist)))
                                (setq newlist (cons (cons 62 color) newlist))
                        ) ;end if
                        (setq ei (1+ ei))
                ) ;end while
                        (reverse newlist)
                ) ;end defun
        (setq ob1 (entsel "\n选择要修改的任何文本:"))
        (SETQ obn (car ob1) ptn (car (cdr ob1 )))
        (setq obt (car (nentselp ptn)))
        (setq oba        (cdr (assoc 0 (entget obt))))
        (if (or (= oba "TEXT")(= oba "MTEXT")(= oba "ATTRIB"))
                (setq otxt (cdr (assoc 1 (entget obt))))
        ) ;end if
        (if (= oba "ATTDEF")
                (setq otxt (cdr (assoc 2 (entget obt))))
        ) ;end if
        (if otxt
                (progn
                        (setq
                                sty (cdr (assoc 7 (entget obt)))
                                lay (cdr (assoc 8 (entget obn)))
                                hig (cdr (assoc 40 (entget obt)))
                                wid (cdr (assoc 41 (entget obt)))
                                ang (cdr (assoc 50 (entget obt)))
                        ) ;end setq
                                (setq col (cdr (assoc 62 (entget obt))))
                                (setq col (cdr (assoc 62 (entget obn))))
                        ) ;end if
                        (setq ang (* 180 (/ ang pi)))
                        (if (null col)(progn (setq cyn 0)(setq col 256))(setq cyn 1))
                        (setq style (style_get_all))
                        (setq layer (layer_get_all))
                        (setq styno (- (length style)(length (member sty style))))
                        (setq layno (- (length layer)(length (member lay layer))))
                        (setq dcl_id1 (load_dialog "文字修改.DCL"))
                        (if (not (new_dialog "文字修改" dcl_id1))(exit))
                        (set_color col)
                        (set_tile "text" otxt)
                        (set_tile "hig" (rtos hig 2 2))
                        (set_tile "wid" (rtos wid 2 2))
                        (set_tile "ang" (rtos ang 2 2))
                        (mode_tile "text" 2)
                        (map_keylist "sty" style)(set_tile "sty" (itoa styno))
                        (map_keylist "lay" layer)(set_tile "lay" (itoa layno))
                        (action_tile "text" "(setq txt $value)")
                        (action_tile "sty"        "(setq styno (atoi $value))")
                        (action_tile "hig"        "(setq hig (distof $value))(if (>= 0 hig)(progn (mode_tile \"hig\" 3)(mode_tile \"hig\" 2)(set_error \"Input error ! \"))(set_error \"\"))")
                        (action_tile "wid"        "(setq wid (distof $value))(if (>= 0 wid)(progn (mode_tile \"wid\" 3)(mode_tile \"wid\" 2)(set_error \"Input error ! \"))(set_error \"\"))")
                        (action_tile "lay"        "(setq layno (atoi $value))")
                        (action_tile "col"        "(if (setq cnu (ACAD_ColorDlg col))(progn (setq col cnu)(set_color col)))")
                        (action_tile "ang"        "(setq ang (distof $value))")
                        (action_tile "accept" "(done_dialog 1)")
                        (action_tile "cancel" "(done_dialog 0)")
                        (if (= 1 (start_dialog))
                                 (if txt
                                        (progn
                                                (setq sty (nth styno style))
                                                (setq lay (nth layno layer))
                                                (setq ang (* (/ ang 180) pi))
                                                (setq etlst (entget obt))
                                                        (setq etlst (subst (cons 2 txt)(assoc 2 etlst) etlst))
                                                        (setq etlst (subst (cons 1 txt)(assoc 1 etlst) etlst))
                                                ) ;end if
                                                (setq etlst (subst (cons 7        sty)(assoc 7        etlst) etlst))
                                                (setq etlst (subst (cons 40 hig)(assoc 40 etlst) etlst))
                                                (setq etlst (subst (cons 41 wid)(assoc 41 etlst) etlst))
                                                (setq etlst (subst (cons 50 ang)(assoc 50 etlst) etlst))
                                                (if (= 1 cyn)
                                                        (setq etlst (subst (cons 62 col)(assoc 62 etlst) etlst))
                                                        (if (= "MTEXT" oba)
        (setq etlst (sub_mtext col etlst))
        (setq etlst (cons (cons 62 col) etlst))
                                                        ) ;end if
                                                ) ;end if
                                                (entmod etlst)
                                                (setq etlst (subst (cons 8        lay)(assoc 8        (entget obn)) (entget obn)))
                                                (entmod etlst)
                                                (entupd obt)
                                                (entupd obn)
                                 ) ;end if
                        );end if
                        (if (= 11 (start_dialog))(Command "_help"))
                ) ;end progn
        ) ;end if
        (setq *error* olderr)
        (EF:UNDOEnd)
        (princ)
) ;end defun
DCL:
//SUPERDDEDIT
文字修改: dialog {
    label    =  "文字编辑...";
    : boxed_radio_column {
       label = "超级文字编辑...";
        : edit_box   { label= "文字:"; key = "text"; edit_width = 50; }
       : row {
        : popup_list {label="样式"; key = "sty"; edit_width = 13; fixed_width = true;}
        : edit_box   {label="高度"; key = "hig"; edit_width =  7; fixed_width = true;}
        : edit_box   {label="宽度"; key = "wid"; edit_width =  7; fixed_width = true;}
       : row {
        : popup_list {label="图层"; key = "lay"; edit_width = 13; fixed_width = true;}
        : image_button {key = "col"; width= 4; aspect_ratio = 0.75; fixed_width = true;}
        : text_part   {key = "cnu"; width= 12;fixed_width = true; }
        : edit_box    {label="角度"; key = "ang"; edit_width =  7; fixed_width = true;}
       spacer_1;
    : row {
          alignment = right;
        : spacer   {width = 1; fixed_width = true;}
       ok_cancel;
     errtile;
发表于 2009-6-6 12:06:04 | 显示全部楼层
辛苦了,真是要好好学习
发表于 2009-6-19 17:52:22 | 显示全部楼层
应即通常是做不到了,我倒是急着用,根本下载不了,等到攒够了积分和金钱,活早就干完了
发表于 2009-7-4 17:54:49 | 显示全部楼层
哎~
积分是关键
发表于 2017-6-13 21:52:12 | 显示全部楼层
修改完的文字没反应
发表于 2019-7-16 12:49:43 来自手机 | 显示全部楼层
学习了,这个看着不错的
来自: 微社区
GMT+8, 2026-11-22 08:24 , Processed in 0.336119 second(s), 20 queries , Gzip On, File On.
