查看: 1052|回复: 0
[LISP程序]:删除顶点,用于LWPOLYLINE,能多选。
发表于 2002-2-8 02:57:59 | 显示全部楼层 |阅读模式
(defun c:dee ( / en el et oldos pt test1 EL1 el2 )
(while
(not
  (eq "LWPOLYLINE" (setq en(car(entsel "\n请选择LWPOLYLINE"))
                        el(entget en)
                        et(cdr (assoc 0 el))))))
(redraw en 3)
(setq OLDOS (getvar "OSMODE"))
(setvar "OSMODE" 1)
(while
(setq PT (getpoint "\n请选择在LWPOLYLINE上将要删除的点")
      TEST1 (cons 10 (list (car PT)(cadr PT)))
      EL1(reverse(cdr(member TEST1 (reverse EL))))
      EL2(cdr(member TEST1 EL)))
(while (and EL2(not (equal (car(car EL2)) 10))  )
        (setq EL2 (cdr EL2)))
(setq EL (append EL1 EL2))
(entmod EL)
(entupd EN))
(setvar "OSMODE" OLDOS))
GMT+8, 2026-11-3 10:33 , Processed in 0.415873 second(s), 31 queries , Gzip On.
