查看: 813|回复: 2
[求助]:什么函数可以用一长度等分一条曲线?
发表于 2004-6-9 11:04:20 | 显示全部楼层 |阅读模式
我想用一长度值来等分一条直线或曲线,然后将等分的点存在数组中,不知何汉书可以实现?请高手指点,谢谢!
已领礼包: 13个
发表于 2004-6-11 03:55:07 | 显示全部楼层
Re: [求助]:什么函数可以用一长度等分一条曲线?
最初由 wang_tianyu 发布
[B]我想用一长度值来等分一条直线或曲线,然后将等分的点存在数组中,不知何汉书可以实现?请高手指点,谢谢! [/B]
AcDbCurve::getSplitCurves(...)
  1. virtual Acad::ErrorStatus
  2. getSplitCurves(
  3. const AcGePoint3dArray& points,
  4. AcDbVoidPtrArray& curveSegments) const;
  5. points Input array of points (in WCS coordinates) on the curve
  6. curveSegments Returns with pointers to newly created entities that are
  7. subcurves of the original
复制代码
你要仅仅得到这些点,而不是实际上把曲线断开,那么先求出曲线上度,然后除以等分数,每段的长度,然后循环下,利用:
  1. AcDbCurve::getPointAtDist Function virtual Acad::ErrorStatus
  2. getPointAtDist(
  3. double unnamed,
  4. AcGePoint3d& unnamed) const;
  5. unnamed Input distance along the curve from the beginning of the curve
  6. to the location of the desired point
  7. unnamed Returns the point located at the location specified by dist
  8. This function determines the point on the curve that is a distance of dist
  9. along the curve from the curve start, and returns the point in point. point is
  10. in WCS coordinates.
  11. Returns Acad::eOk if successful. If dist is not valid for the curve, then
  12. Acad::eInvalidInput is returned. Other ErrorStatus return values are
  13. implementation-dependent.
  14. The default implementation returns Acad::eNotImplemented.
发表于 2004-6-11 19:12:41 | 显示全部楼层
你可以用getStartParam 得到起点的"参数"dParamS,getEndParam 得到终点的"参数"dParamE,然后(dParamE-dParamS)/等分数,得每份的参数 n ,再用getPointAtDist(dParamS + n*i),得每等分点的坐标.
(对于cad的实体  参数 正比于 长度,自定义实体就难说了)
GMT+8, 2026-11-6 00:16 , Processed in 0.389273 second(s), 35 queries , Gzip On.
