查看: 618|回复: 1
[讨论]:一个部分屏蔽双击事件的例子
发表于 2004-6-11 10:07:57 | 显示全部楼层 |阅读模式
Private pUnLoadDbClick As Boolean
Private Sub AcadDocument_BeginDoubleClick(ByVal PickPoint As Variant)
Dim ss As AcadSelectionSet
Dim pobj As AcadEntity
    Set ss = ThisDrawing.PickfirstSelectionSet
    Set pobj = ss(0)
    If ss.Count = 1 And pobj.EntityName = "AcDbBlockReference" Then
        If Not pUnLoadDbClick Then Application.UnloadArx "acdblclkedit.arx": pUnLoadDbClick = True
    Else
        If pUnLoadDbClick Then Application.LoadArx "acdblclkedit.arx": pUnLoadDbClick = False
    End If
End Sub
 楼主| 发表于 2004-6-11 10:59:25 | 显示全部楼层
我用的是加载卸载acdblclkedit.arx的办法,2005里调试通过,各位有没有好一点的其他办法?
GMT+8, 2026-11-3 06:25 , Processed in 0.483673 second(s), 34 queries , Gzip On.
