查看: 3577|回复: 3
[求助] [求助]:这个LISP缺少什么?
已领礼包: 12个
发表于 2006-6-5 12:40:05 | 显示全部楼层 |阅读模式
代码如下:
  1.   [FONT=courier new]
  2. ;;另类图元隐藏/显示,通过建立组隐藏实体
  3. ;|
  4. visible
  5. object.Visible
  6. object
  7.       All Drawing objects, Application, AttributeReference, Group, Toolbar
  8.       The object or objects this property applies to.
  9. Boolean; read-write (write-only for the Group object)
  10. TRUE:    The object or application is visible.
  11. FALSE:   The object or application is not visible.
  12. Remarks
  13. If you specify an object to be invisible, it will be invisible regardless of
  14. the application visible setting. Other factors can also cause an object to be
  15. invisible; for example, an objectwill not be displayed if its layer is off or
  16. frozen.
  17. Specifying the application to be invisible allows you to run tasks in the
  18. background without having to see the component.
  19. Specifies the visibility of an object or the application.
  20. All Drawing objects, Application, AttributeReference, Group, Toolbar
  21. |;
  22. (defun ea:SSonoff (tf s mode / groups gl)
  23.   (setvar "cmdecho" 0)
  24.   ;;检测是否有特定组
  25.   (if (vl-catch-all-error-p
  26.         (vl-catch-all-apply
  27.           'vla-item
  28.           (list
  29.             (setq
  30.               groups
  31.                (vla-get-groups
  32.                  (vla-get-activedocument (vlax-get-acad-object))
  33.                )
  34.             )
  35.             "ea_hide_object"
  36.           )
  37.         )
  38.       )
  39.     (progn
  40.       (setq gr (vla-add groups "ea_hide_object"));添加组
  41.       (setq gl (entget (vlax-vla-object->ename gr)))
  42.       (entmod (subst '(71 . 0)
  43.                      (assoc 71 gl)
  44.                      gl
  45.               )
  46.       );不可选择
  47.     );end progn
  48.   );end if
  49.   (if (not tf)
  50.     (progn
  51.       (command ".select" "all" "r" s "")
  52.       (command ".group" "a" "ea_hide_object" "p" "")
  53.     );隔离隐藏用
  54.     (command ".group" "a" "ea_hide_object" s "")
  55.   )
  56.   (vla-put-visible
  57.     (vla-item groups "ea_hide_object")
  58.     mode
  59.   );隐藏组,实体将不拥有 62 组码
  60.   (princ)
  61. )
  62. ;;隐藏选择实体
  63. (defun c:Hideobj (/ ss)
  64.   (if (progn (princ "\n选择要隐藏的实体...")
  65.              (setq ss (ssget))
  66.       )
  67.     (ea:SSonoff t ss :vlax-false)
  68.   )
  69.   (princ)
  70. )
  71. ;;显示全部实体
  72. (defun c:Showall (/ ss)
  73.   (setvar "pickstyle" 0)
  74.   (if (not (vl-catch-all-error-p
  75.              (vl-catch-all-apply
  76.                'vla-item
  77.                (list
  78.                  (setq
  79.                    groups
  80.                     (vla-get-groups
  81.                       (vla-get-activedocument (vlax-get-acad-object))
  82.                     )
  83.                  )
  84.                  "ea_hide_object"
  85.                )
  86.              )
  87.            )
  88.       )
  89.     (progn
  90.       (vla-put-visible
  91.         (vla-item groups "ea_hide_object")
  92.         :vlax-true
  93.       )
  94.       (command ".group" "e" "ea_hide_object");清除组
  95.     )
  96.   )
  97.   (princ)
  98. )
  99. ;;隐藏非选择实体
  100. (defun c:ISOobj        (/ ss)
  101.   (if (progn (princ "\n选择隔离实体....")
  102.              (setq ss (ssget))
  103.       )
  104.     (ea:ssonoff nil ss :vlax-false)
  105.   )
  106.   (princ)
  107. )
  108. (princ "\n\t命令: HideObj ShowAll IsoObj.")
  109.   [/FONT]
运行后说“错误: no function definition: VLAX-GET-ACAD-OBJECT"
`请问怎样解决啊?
已领礼包: 593个
发表于 2006-6-5 12:45:03 | 显示全部楼层
你用的什么版本CAD?2000 和2002 先执行 (vl-load-com)  后再试
已领礼包: 12个
 楼主| 发表于 2006-6-5 14:32:30 | 显示全部楼层
多谢斑竹,搞定了。
但关闭了CAD2002,再启动后又要输入(vl-load-com)
有没有办法一次解决?
顺便问下(vl-load-com)是什么意思?
发表于 2006-6-7 07:52:34 | 显示全部楼层
你调用的那些函数vl-catch-all-error-p。。。。。。
都是在一个函数库中的,所以先加载函数库
GMT+8, 2026-11-3 06:02 , Processed in 0.625281 second(s), 38 queries , Gzip On.
