查看: 921|回复: 3
[LISP函数]:在cad2005 support里面发现的晓东lsp
发表于 2004-6-15 19:54:04 | 显示全部楼层 |阅读模式
请问这个怎么用啊 谁能发一个动画演示
    ; MODULE_ID ACAD2005_LSP_
    ;;;    ACAD2005.LSP Version 1.0 for AutoCAD 2005
    ;;;    Copyright (C) 1994-2003 by Autodesk, Inc.
    ;;;    Permission to use, copy, modify, and distribute this software
    ;;;    for any purpose and without fee is hereby granted, provided
    ;;;    that the above copyright notice appears in all copies and
    ;;;    that both that copyright notice and the limited warranty and
    ;;;    restricted rights notice below appear in all supporting
    ;;;    documentation.
    ;;;    AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
    ;;;    AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
    ;;;    MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
    ;;;    DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
    ;;;    UNINTERRUPTED OR ERROR FREE.
    ;;;    Use, duplication, or disclosure by the U.S. Government is subject to
    ;;;    restrictions set forth in FAR 52.227-19 (Commercial Computer
    ;;;    Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
    ;;;    (Rights in Technical Data and Computer Software), as applicable.
    ;;;    Note:
    ;;;            This file is normally loaded only once per AutoCAD session.
    ;;;            If you wish to have LISP code loaded into every document,
    ;;;            you should add your code to acaddoc.lsp.
    ;;;    Globalization Note:
    ;;;            We do not support autoloading applications by the native
    ;;;            language command call (e.g. with the leading underscore
    ;;;            mechanism.)
    (if (not (=  (substr (ver) 1 11) "Visual LISP")) (load "acad2005doc.lsp"))
    ;; Silent load.
    (princ)
    (defun c:XDTB_CopyWithDoteInt ()
      (prompt "\n请选取要沿轴交点拷贝的实体<退出>:")
      (setq dote_lyr (xdrx_getlyrname "轴线"))
      (if (and
            (setq ss (ssget))
            (setq pj (xdrx_getpoint "\n请拾取基点<退出>:"))
            (setq e (xdrx_entsel "\n请拾取一条轴线作为路径<退出>:"))
        (progn
          (xdrx_begin)
          (xdrx_sysvar_push "osmode" "cmdecho")
          (setvar "osmode" 0)
          (setvar "cmdecho" 0)
          (setq p1 (xdrx_getentdxf 10)
                p2 (xdrx_getentdxf 11)
                tf (xdrx_isptoffscr p1 p2)
          (if tf
            (progn
              (xdrx_drawing_viewsave)
              (xdrx_drawing_zoomw p1 p2)
          (setq intl (xdrx_getinters
                       e
                       (ssget "f"
                              (list p1 p2)
                              (list
                                (cons 8 dote_lyr)
                                 (0 . "line")
          (foreach n intl
            (if (not (equal n pj 1e-5))
              (command ".copy" ss "" pj n)
              (princ "ok")
          (xdrx_sysvar_pop)
          (xdrx_end)
      (princ)
发表于 2004-6-27 18:40:50 | 显示全部楼层
大家来看看
发表于 2004-6-27 20:13:29 | 显示全部楼层
真的么?文件名是什么?我看看我这里有没有:)
 楼主| 发表于 2004-6-28 18:56:57 | 显示全部楼层
怎么没人知道吗 我是菜鸟  谁能给个动画演示 谢谢
GMT+8, 2026-11-6 19:11 , Processed in 0.424459 second(s), 38 queries , Gzip On.
