查看: 854|回复: 0
[讨论]:VB.Net的事件处理
发表于 2004-6-22 09:46:07 | 显示全部楼层 |阅读模式
原理,在VBA的窗体激活事件中改变USERS系统变量,VB.Net接收该事件将文档级事件处理激活到当前文档
总觉得不太妥当,有好点的办法麽?
VB.Net - Module mTlsCad代码
    Private WithEvents pACadApp As AcadApplication = Application.AcadApplication
    Private WithEvents pACadDoc As AcadDocument = pACadApp.ActiveDocument
    Private Sub pACadApp_SysVarChanged(ByVal SysvarName As String, ByVal newVal As Object) Handles pACadApp.SysVarChanged
        If SysvarName.ToUpper = "*USERS5" Then pACadDoc = pACadApp.ActiveDocument
    End Sub
    Private Sub pACadDoc_BeginDoubleClick(ByVal PickPoint As Object) Handles pACadDoc.BeginDoubleClick
        Dim ss As AcadSelectionSet
        ss = pACadDoc.PickfirstSelectionSet
        If ss.Count = 0 Then
            Exit Sub
        ElseIf ss.Count = 1 Then
            Select Case ss.Item(0).EntityName
                Case "AcDbBlockReference"
                    If ss.Item(0).HasAttributes Then
                        pACadDoc.SendCommand("_.eattedit" & vbCr & vbCr & vbCr)
                    End If
                Case "AcDbText", "AcDbMText"
                    pACadDoc.SendCommand("_.ddedit" & vbCr & vbCr)
                Case Else
                    pACadDoc.SendCommand("_.properties" & vbCr)
            End Select
        Else
        End If
    End Sub
VBA - ThisDrawing代码
Private Sub AcadDocument_Activate()
    Dim pUser As String
    pUser = ThisDrawing.GetVariable("USERS5")
    ThisDrawing.SetVariable "USERS5", str(Now)
    ThisDrawing.SetVariable "USERS5", pUser
End Sub
GMT+8, 2026-11-22 11:21 , Processed in 0.305143 second(s), 10 queries , Gzip On, File On.
