查看: 959|回复: 2
[其他]:系统响铃
发表于 2003-9-7 10:53:48 | 显示全部楼层 |阅读模式
  1. '在窗体上增加一个CommandButton控件
  2. Private Declare Function Beep Lib "kernel32" (ByVal dwFreq As Long, ByVal dwDuration As Long) As Long
  3. Private Sub CommandButton1_Click()
  4. 'Attempt to play a note at 800Hz for 2 seconds. This will only
  5. 'behave this way on Windows NT/2000;users of Windows 95/98 will hear the
  6. 'default sound
  7. Dim retval As Long 'return value
  8. retval = Beep(800, 2000) 'ideally,an 800Hz tone for 2 seconds
  9. End Sub
 楼主| 发表于 2003-9-7 12:28:24 | 显示全部楼层
隐藏鼠标
如果图形附带上这个DVB如何,开玩笑了
  1. Private Declare Function ShowCursor Lib "user32" (ByVal bShow As Long) As Long
  2. Public Sub Form_load()
  3. ShowCursor 0
  4. t = Timer
  5. Do: DoEvents: Loop Until Timer > t + 10
  6. ShowCursor 1
  7. End Sub
发表于 2003-9-12 00:36:27 | 显示全部楼层
是否可以继续本贴!
多发一些好玩的代码?
GMT+8, 2026-11-22 11:04 , Processed in 0.388042 second(s), 14 queries , Gzip On, File On.
