查看: 1264|回复: 11
[分享]:lisp程序
已领礼包: 6个
发表于 2004-6-29 09:21:48 | 显示全部楼层 |阅读模式
[php]
(defun buyit (/)
  (startapp "\\sai_toolbox\\icalc\\support\\autoflsh.exe")
(defun regnow (/)
  (setq key (get_tile "keycode"))
  (if (= key "")
    (setq key nil)
  (if (= key " ")
    (setq key nil)
  (if (= key "  ")
    (setq key nil)
  (if (= key "   ")
    (setq key nil)
  (if (= key "    ")
    (setq key nil)
  (if (= key nil)
    (help "\\sai_toolbox\\icalc\\ICaLCH" "Authorizing")
  (while (/= key nil)
    (setq key (atof key))
    (setq can2 (atof can))
    (setq keycodechk (- key can2))
    (setq keycodechk (rtos keycodechk 2 4))
    (setq keycodechk2 "123456.7891")
    (if (/= keycodechk2 keycodechk)
      (alert "Invalid Key Code")
    (if (= keycodechk2 keycodechk)
      (alert "Icalc is now Authorized...")
    (princ)
      (progn
        (setq usefl (open "\\C000R000.dll" "w"))
        (write-line "3" usefl)
        (write-line can usefl)
        (close usefl)
    (setq key nil)
;;;Authorizing Module;;;;;;;;
(defun auth (/)
  (setq fnddllfl (findfile "\\C000R000.dll"))
  (if (= fnddllfl nil)
    (progn
      (setq dte (getvar "DATE"))
      (setq can (rtos dte 2 4))
      (setq dllfile (open "\\C000R000.dll" "w"))
      (write-line "0" dllfile)
      (write-line can dllfile)
      (close dllfile)
  (setq dllfile (open "\\C000R000.dll" "r"))
  (setq amode (read-line dllfile))
  (setq can (read-line dllfile))
  (close dllfile)
  (setq canline (strcat "Your Customer Authorization Number is:  IC" can "D"))
  (setq dte (rtos dte 2 0))
  (setq dte (atoi dte))
  (setq can1 (atoi can))
  (setq endd (+ can1 15))
  (setq checkdemo (- endd dte))
  (setq demodays (rtos checkdemo 2 0))
  (setq countdown (strcat "You have " demodays " Days left of this Evaluation!"))
  (if (/= amode "3")
    (progn
      (setq checkdemo (minusp checkdemo))
      (if (/= checkdemo nil)
        (setq amode "2")
  (if (/= amode "3")
    (progn                           ;
      ;;;crt;;;(setq dcl_id (load_dialog "\\sai_toolbox\\icalc\\auth.dcl"))
      (setq dcl_id (load_dialog "auth.dcl"))
      (if (not (new_dialog "auth" dcl_id))
        (exit)
      (if (/= amode "2")
        (set_tile "dmode" countdown)
      (set_tile "canum" canline)     ;
      (action_tile "regnow" "(regnow)")
      (action_tile "accept" "(done_dialog)")
      (action_tile "buynow" "(buyit)") ;
      (start_dialog)
      (unload_dialog dcl_id)
  (if (= amode "2")
    (setq calcrun 3)
;;;                  Authorizing program!
(defun ichelp (/)
  (help "\\sai_toolbox\\icalc\\icalch" "Contents")
(defun readcalc (/)
  (setq 000read000 (get_tile "calbox"))
(defun chgprec (/)
  (setq newprec (get_tile "precbox"))
  (setq newprec (atoi newprec))
  (setvar "LUPREC" newprec)
(defun cmem (/)
  (setq 000remem000 nil)
  (set_tile "memory" "Memory")
(defun rmem (/)
  (if (/= 000remem000 nil)
    (set_tile "calbox" 000remem000)
(defun msto (/)
  (setq 000remem000 (get_tile "calbox"))
  (if (= 000remem000 nil)
  (if (= 000remem000 "")
  (if (= 000remem000 " ")
    (progn
      (setq memsho (strcat "Memory = " 000remem000))
      (set_tile "memory" memsho)
(defun clrcalc (/)
  (set_tile "calbox" "")
  (setq hold1 nil)
  (set_tile "stus" "Ready")
(defun rtvarea (/)
  (setq eop (getstring "\nAREA: Entity or Points [E / P] : "))
  (setq eop (strcase eop))
  (if (= eop "E")
    (setq e (entsel "\nSelect Entity: "))
  (if (/= eop "E")
    (progn
      (setq pt1 1)
      (setq pntlist (list 1))
      (while (/= pt1 nil)
        (setq pt1 (getpoint "\nNext Point:"))
        (if (/= pt1 nil)
          (progn
            (setq pt1 (reverse pt1))
            (setq pt1 (cdr pt1))
            (setq pt1 (list pt1))
            (setq pntlist (append pntlist pt1))
      (setq pntlist (cdr pntlist))
  (setq echo (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (command "area")
  (if (= eop "E")
    (command "E")
  (if (/= eop "E")
    (progn
      (foreach pnt pntlist (command pnt))
  (if (= eop "E")
    (command e)
  (if (/= eop "E")
    (command "")
  (setq sfarea (getvar "AREA"))
  (princ sfarea)
  (setq retreive (rtos sfarea 2 4))
  (setq retvmode nil)
  (setvar "CMDECHO" echo)
(defun rtvelev (/)
  (setq pt1 nil)
  (setq pt1 (getpoint "\nELEVATION: Select Point:"))
  (if (/= pt1 nil)
    (progn
      (setq elev1 (caddr pt1))
      (setq retreive (rtos elev1 2 4))
  (if (= pt1 nil)
    (setq retreive nil)
  (if (= pt1 nil)
    (alert "No Point Selected")
  (setq retvmode nil)
(defun rtvrad (/)
  (arxload "geomcal" '("cal" "cal"))
  (setq radrt (cal "rad"))
  (princ radrt)
  (setq retreive (rtos radrt 2 4))
  (setq retvmode nil)
(defun rtvzdist (/)
  (setq pt1 nil)
  (setq pt2 nil)
  (setq pt1 (getpoint "\nZ DISTANCE: Select First Point:"))
  (if (/= pt1 nil)
    (setq pt2 (getpoint pt1 "\nSelect Second Point:"))
  (if (/= pt2 nil)
    (progn
      (setq pt1 (caddr pt1))         ;
      (setq pt2 (caddr pt2))         ;
      (setq zdistrt (- pt1 pt2))
      (setq zdistrt (abs zdistrt))
      (setq retreive (rtos zdistrt 2 4))
  (if (= pt1 nil)
    (setq retreive nil)
  (if (= pt2 nil)
    (setq retreive nil)
  (if (= pt2 nil)
    (alert "No Distance Selected")
  (setq retvmode nil)
(defun rtvsdist (/)
  (setq pt1 nil)
  (setq pt2 nil)
  (setq pt1 (getpoint "\nSLOPE DISTANCE: Select First Point:"))
  (if (/= pt1 nil)
  (if (/= pt2 nil)
    (progn
      (setq sdistrt (distance pt1 pt2))
      (setq retreive (rtos sdistrt 2 4))
  (if (= pt1 nil)
    (setq retreive nil)
  (if (= pt2 nil)
    (setq retreive nil)
  (if (= pt2 nil)
  (setq retvmode nil)
(defun rtvhdist (/)
  (setq pt1 nil)
  (setq pt2 nil)
  (setq pt1 (getpoint "\nSelect First Point:"))
  (if (/= pt1 nil)
    (setq pt2 (getpoint pt1 "\nDISTANCE: Select Second Point:"))
  (if (/= pt2 nil)
    (progn
      (setq pt1 (reverse pt1))       ;
      (setq pt2 (reverse pt2))
      (setq pt2 (cdr pt2))
      (setq pt2 (reverse pt2))       ;
      (setq hdistrt (distance pt1 pt2))
      (setq retreive (rtos hdistrt 2 4))
  (if (= pt1 nil)
    (setq retreive nil)
  (if (= pt2 nil)
    (setq retreive nil)
  (if (= pt2 nil)
  (setq retvmode nil)
(defun rtvang (/)
  (setq angpt nil)
  (setq angpt (getpoint "\nANGLE: Select First Angle Point"))
  (if (/= angpt nil)
    (progn
      (setq angrt (getangle angpt "\nSecond Angle Point"))
      (setq retreive (angtos angrt 0 4))
  (if (= angpt nil)
    (setq retreive nil)
  (if (= angpt nil)
    (alert "No Angle Selected")
  (setq retvmode nil)
(defun trigfunc (/)
  (setq num (get_tile "calbox"))
  (setq num (atof num))              ;
  (if (= func 5)
    (progn
      (setq newnum (sqrt num))
  (if (= func 6)
    (progn
      (setq newnum (* num num))
  (if (= func 7)
    (progn
      (setq newnum (* newnum num))
  (if (= func 8)
    (progn
      (setq num (rtos num 2 8))
      (setq num (angtof num 0))
      (setq newnum (sin num))
  (if (= func 9)
    (progn
      (setq newnum (cos num))
  (if (= func 10)
    (progn
      (if (/= num 90)
        (setq newnum (cal "tang(num)"))
      (if (= num 90)
        (alert "Invalid input for function")
      (if (= num 90)
        (setq newnum 0)
  (if (= func 11)
    (progn
      (if (> num 0)
        (setq newnum (log num))
      (if (<= num 0)
        (setq newnum 0)
      (if (<= num 0)
  (if (= func 12)
    (progn
      (setq num (rtos num))
      (setq newnum (angtos num 1 5))
  (if (= func 13)
    (progn
      (setq negchk (minusp num))
      (if (/= negchk nil)
        (setq newnum (abs num))
      (if (= negchk nil)
        (progn
          (setq dbl (* num 2))
          (setq newnum (- num dbl))
  (if (/= func 12)
    (setq newnum (rtos newnum))
  (set_tile "calbox" newnum)
(defun runfunc (/)
  (setq newnum nil)
  (if (= num nil)
    (setq num "0")
  (if (= num "")
    (setq num "0")
  (if (= num " ")
    (setq num "0")
  (if (= num "  ")
    (setq num "0")
  (if (= num "   ")
    (setq num "0")
  (if (= num "    ")
    (setq num "0")
  (if (= hold1 nil)
    (setq hold1 "0")
  (setq hold1 (atof hold1))          ;
  (if (= func 1)
    (progn
      (setq newnum (+ num hold1))
  (if (= func 2)
    (progn
      (setq newnum (- hold1 num))
  (if (= func 3)
    (progn
      (setq newnum (* hold1 num))
  (if (= func 4)
    (progn
      (setq newnum (/ hold1 num))
  (if (/= newnum nil)
  (if (/= newnum nil)
  (setq hold1 nil)
  (setq func nil)
(defun clrent (/)
(defun hold (/)
  (setq hold1 (get_tile "calbox"))   ;
  (if (= func 1)
    (setq action "Adding... ")
  (if (= func 2)
    (setq action "Subtract... ")
  (if (= func 3)
    (setq action "Multiply... ")
  (if (= func 4)
    (setq action "Divide... ")
  (setq status (strcat action hold1))
  (set_tile "stus" status)
  (clrent)
(defun setnum1 (/)
  (setq ritenum "00")
  (setq newnum (strcat num ritenum))
(defun setnum2 (/)
  (setq ritenum ".")
(defun setnum (/)
  (setq ritenum (rtos ritenum 2 0))
(defun mainclc (/)
  (setq precboxlst (list "0" "0.0" "0.00" "0.000" "0.0000" "0.00000" "0.000000"
                       "0.0000000" "0.00000000"
  ;;;crt;;;(setq dcl_id (load_dialog "\\sai_toolbox\\icalc\\calc.dcl"))
  (setq dcl_id (load_dialog "calc.dcl"))
  (if (not (new_dialog "calc" dcl_id))
    (exit)
  (if (/= hold1 nil)
  (if (/= retreive nil)
    (set_tile "calbox" retreive)
  (princ "\nCalculator Ready...")
  (princ)                            ;
  (action_tile "one" "(setq ritenum 1)(setnum)")
  (action_tile "two" "(setq ritenum 2)(setnum)")
  (action_tile "three" "(setq ritenum 3)(setnum)")
  (action_tile "four" "(setq ritenum 4)(setnum)")
  (action_tile "five" "(setq ritenum 5)(setnum)")
  (action_tile "six" "(setq ritenum 6)(setnum)")
  (action_tile "seven" "(setq ritenum 7)(setnum)")
  (action_tile "eight" "(setq ritenum 8)(setnum)")
  (action_tile "nine" "(setq ritenum 9)(setnum)")
  (action_tile "zero" "(setq ritenum 0)(setnum)")
  (action_tile "dzero" "(setnum1)")
  (action_tile "dcpt" "(setnum2)")   ;
  (action_tile "plus" "(setq func 1)(hold)")
  (action_tile "minus" "(setq func 2)(hold)")
  (action_tile "multiply" "(setq func 3)(hold)")
  (action_tile "divide" "(setq func 4)(hold)")
  (action_tile "sqrt" "(setq func 5)(trigfunc)")
  (action_tile "xsqr" "(setq func 6)(trigfunc)")
  (action_tile "xcube" "(setq func 7)(trigfunc)")
  (action_tile "xsin" "(setq func 8)(trigfunc)")
  (action_tile "xcos" "(setq func 9)(trigfunc)")
  (action_tile "xtan" "(setq func 10)(trigfunc)")
  (action_tile "xlog" "(setq func 11)(trigfunc)")
  (action_tile "xdms" "(setq func 12)(trigfunc)")
  (action_tile "chgsgn" "(setq func 13)(trigfunc)")
  (action_tile "equals" "(runfunc)") ;
  (action_tile "gtang" "(done_dialog)(setq retvmode 1)")
  (action_tile "gdist" "(done_dialog)(setq retvmode 2)")
  (action_tile "gslope" "(done_dialog)(setq retvmode 3)")
  (action_tile "gvdist" "(done_dialog)(setq retvmode 4)")
  (action_tile "grad" "(done_dialog)(setq retvmode 5)")
  (action_tile "gele" "(done_dialog)(setq retvmode 6)")
  (action_tile "garea" "(done_dialog)(setq retvmode 7)")
  (action_tile "precbox" "(chgprec)") ;
  (action_tile "clear" "(clrcalc)")  ;
  (action_tile "rm" "(rmem)")
  (action_tile "cm" "(cmem)")
  (action_tile "sm" "(msto)")        ;
  (action_tile "accept" "(readcalc)(setq calcrun 1)(done_dialog)")
  (action_tile "help" "(ichelp)")    ;
  (start_list "precbox")             ;Specify the name of the list box
  (mapcar 'add_list precboxlst)      ;Specify the AutoLISP list
  (end_list)                         ;
  (set_tile "precbox" prec)          ;
  (start_dialog)
  (done_dialog)                      ;
  (if (= retvmode 1)
    (rtvang)
  (if (= retvmode 2)
    (rtvhdist)
  (if (= retvmode 3)
    (rtvsdist)
  (if (= retvmode 4)
    (rtvzdist)
  (if (= retvmode 5)
    (rtvrad)
  (if (= retvmode 6)
    (rtvelev)
  (if (= retvmode 7)
    (rtvarea)
(defun c:icalc (/)
  (setq prec (getvar "LUPREC"))
  (setq prec (itoa prec))
  (setq calcrun 0)
  (setq retreive nil)
  ;;;crt;;;(auth)
  (while (= calcrun 0)
    (mainclc)
  (if (= calcrun 1)
    (command 000read000)
[/php]
发表于 2004-6-29 09:51:25 | 显示全部楼层
老大能不能解释一下,看不太懂,是不是计算的程序啊。
发表于 2004-6-29 09:53:03 | 显示全部楼层
有个说明就好了
发表于 2004-6-29 10:56:07 | 显示全部楼层
请教一下楼主,这个程序能实现什麽功能啊?
已领礼包: 3720个
发表于 2004-7-1 21:11:29 | 显示全部楼层
程序是干什么用的?
已领礼包: 1915个
财富等级: 堆金积玉
发表于 2004-7-2 09:48:53 | 显示全部楼层
像这样没头没脑的程序建议版主扣分
发表于 2004-7-2 09:55:10 | 显示全部楼层
autolisp
发表于 2004-7-2 12:20:21 | 显示全部楼层
最初由 小雨思铃 发布
[B]autolisp [/B]
然後呢?
发表于 2004-7-2 12:37:57 | 显示全部楼层
莫名其妙
发表于 2004-7-2 14:49:53 | 显示全部楼层
大概是从某个软件里面摘下来的吧,没有那个软件,这些lisp也没什么大用处,最多是参考一下罢了,但是谁有这个心思呢?
(defun buyit (/)
  (startapp "\sai_toolbox\icalc\support\autoflsh.exe")
sai_toolbox   , sai,得赛?
发表于 2004-7-2 15:22:53 | 显示全部楼层
变态垃圾帖
斑竹口分啊
发表于 2004-7-2 22:03:38 | 显示全部楼层
楼主应该给说明一下的
GMT+8, 2026-11-4 21:04 , Processed in 0.503121 second(s), 54 queries , Gzip On.
