查看: 1018|回复: 5
[LISP函数]:一个很好用的画截断线的LISP
发表于 2004-6-29 22:35:22 | 显示全部楼层 |阅读模式
一个很好用的画截断线的LISP
defun c:JDX ()
     (setq oldos (getvar "osmode"))
     (setq oldpk (getvar "pickbox"))
     (setvar "pickbox" 0)
     (setvar "osmode" 0)
     (setq scal1 (getreal "\nenter the relative <12>:"))
     (if (= scal1 nil) (setq scal1 12))
     (setq XY1 (getpoint "\nfirst  point:"))
     (setq XY2 (getpoint XY1 "\nsecnod point:"))
     (brkli scal1 XY1 XY2)
     (setvar "pickbox" oldpk)
     (setvar "osmode"  oldos)
(defun brkli (scal1 XY1 XY2)
       (setq a (angle XY1 XY2))
       (setq d (distance XY1 XY2))
       (setq XY3 (polar XY1  a (/ d 2)))
       (setq XY4 (polar XY3  (- a (* 4 (/ pi 4))) (* (/ d scal1) 1    )))
       (setq XY5 (polar XY3  (+ a (* 3 (/ pi 4))) (* (/ d scal1) 1.414)))
       (setq XY6 (polar XY3  (- a (* 1 (/ pi 4))) (* (/ d scal1) 1.414)))
       (setq XY7 (polar XY3  (- a (* 0 (/ pi 4))) (* (/ d scal1) 1    )))
       (command "pline" XY1 "w" "0" "0" XY4 XY5 XY6 XY7 XY2 "")
发表于 2004-6-29 22:44:13 | 显示全部楼层
程序没法执行
前面少了一个括号
发表于 2004-6-30 01:07:20 | 显示全部楼层
有需要将PICKBOX设为0 吗?
发表于 2004-6-30 09:01:15 | 显示全部楼层
这个到是需要,避免选择的点捕捉到不需要的地方,比如圆心、端点等。
发表于 2004-6-30 09:16:59 | 显示全部楼层
PICKBOX is object selection target height and has nothing to do with Snap
发表于 2004-6-30 14:55:28 | 显示全部楼层
的确挺好用的,但是截断线形状如何修改?
GMT+8, 2026-11-4 23:00 , Processed in 0.483536 second(s), 42 queries , Gzip On.
