查看: 827|回复: 0
[LISP程序]:批量处理离圆最近的文本对齐圆中心
发表于 2004-7-15 07:40:17 | 显示全部楼层 |阅读模式
批量处理离圆最近的文本对齐圆中心
[php]
(defun c:test ( / ssl ttl ntt)
  ;(vl-load-com)
  (setq ss (ssget '((0 . "CIRCLE,TEXT"))))
  (foreach i (acet-ss-to-list ss)
    (if (= (cdr (assoc 0 (entget i))) "CIRCLE")
      (setq ssl (cons i ssl))
      (setq ttl (cons i ttl))
  (foreach i ssl
    (setq pc (cdr (assoc 10 (entget i))))
    (setq ntt
      (vl-sort ttl
        (function
          (lambda (e1 e2)(< (distance pc (cdr (assoc 10 (entget e1))))
                            (distance pc (cdr (assoc 10 (entget e2)))))
    (setq obj (vlax-ename->vla-object (car ntt)))
    (vla-put-alignment obj 4)
    (vla-put-TextAlignmentPoint obj (vlax-3d-point pc))
[/php]
GMT+8, 2026-11-4 22:48 , Processed in 0.510147 second(s), 38 queries , Gzip On.
