查看: 693|回复: 2
[传贴]:螺旋结构 有兴趣的进来~!
发表于 2004-7-16 18:28:17 | 显示全部楼层 |阅读模式
先用拉伸路径的方法画弹簧    然后把弹簧再沿一段螺旋路径弯曲   重点是找准每实体圆截面的圆心  不用拼接和阵列  下班前我做了大约30分钟  更高效的办法是编程解决
你画的不错 最好渲出好点的效果  这样就有一比了
下面是一段LISP代码,加载后就可以画了
(defun shuru ()
    (setq zhijing (getREAL "公称直径:"))
    (setq luoju (getreal "螺距:"))
    (SETQ QUANSHU (GETREAL "螺纹有效圈数:"))
    (SETQ JINGDU (GETint "每转切割次数:"))
    (setq QIDIAN (getpoint "输入起始点:"))
(defun JISUAN ()
(setq H (* 0.8660254 luoju))
(setq D2 (- zhijing (* 2 0.375 H)))
        (SETQ LD2 (* D2 PI))
        (SETQ LUOXUANJIAO (ATAN (/ LUOJU LD2)))
            (SETQ LXJ (* 180 (/ LUOXUANJIAO pi)))
              (setq banjiao(atan(/ luoju zhijing)))
                (setq djxc (sqrt(+ (expt luoju 2) (expt zhijing 2))))
                  (setq pyj (+ banjiao luoxuanjiao))
                (setq pianyi (* (sin pyj) djxc))
                  (setq pianyi (/ pianyi 2.0000))
        (SETQ SL (fix (* (+ 1 QUANSHU) JINGDU )))
        (SETQ FD (/ 360.0000 JINGDU))
        (SETQ BC (/ (* 1.0000 LUOJU) JINGDU))
          (setq bc (- bc))
  (defun draw ()
(setq pt1 (polar QIDIAN PI (/ LUOJU 2.0000)))
            (SETQ PT1 (POLAR PT1 (* 1.5 PI) (+ (* 0.1250 H) (/ ZHIJING 2.0000))))
(setq pt2 (polar pt1 0 (* luoju 0.375 (cos LUOXUANJIAO))))
            (SETQ PT2 (POLAR PT2 (* 0.5 PI) (* 0.750 H)))
(setq pt3 (polar pt2 0 (* 0.25 LUOJU (cos LUOXUANJIAO))))
(setq pt4 (polar pt1 0 (* LUOJU (cos LUOXUANJIAO))))
(setq pt5 (polar QIDIAN pi (* 2.00 LUOJU QUANSHU)))
(setq pt7 (polar pt5 0 (* 2 LUOJU)))
     (setq pt7 (polar pt7 (* 1.5 pi) (/ ZHIJING 2)))
(setq pt6 (polar pt5 0 LUOJU))
            (SETQ PT6 (POLAR PT6 (* 0.5 PI) (* 0.50000 ZHIJING)))
        (SETQ PT8 (POLAR PT1 0 (* 0.5 LUOJU)))
        (SETQ PT9 (POLAR PT8 (* 0.5 PI) (* 0.8 ZHIJING)))
            (SETQ MV (POLAR QIDIAN 0 (/ ZHIJING 2.0000)))
;制做齿条并转角
    (command "pline" pt1 pt2 pt3 pt4 "c" )
    (command "extrude" "last" "" ZHIJING "" )
       (setq SS (ssget pt1))
       (rotate3d ss PT9 PT8 90)
         (COMMAND "MOVE" "Previous" "" QIDIAN MV )
           (rotate3d ss "" PT8 PT9 90)
    (rotate3d ss "" PT9 PT8 LXJ)
    (SETQ YD (POLAR QIDIAN 0 (/ LUOJU 2.0000)))
    (COMMAND "MOVE" "Previous" "" QIDIAN YD )
;制做光杆
    (SETQ PT0 (POLAR QIDIAN 0  LUOJU))
    (COMMAND "LINE" PT5 PT0 "")
    (COMMAND "rectang" PT6 QIDIAN)
    (COMMAND "revolve" "LAST" "" PT5 qidian "")
    (command "zoom" "e")
;布尔运算
    (SETQ PT (POLAR PT4 0 pianyi))
    (SETQ SQ pt6)
    (while (/= SL 0)
       (SETQ SS (SSGEt pt))
         (setq pta (polar pt 0 bc))
        (command "copy" ss "" pt pta)
;        (prin1 pt)
(COMMAND "subtract" sq "" ss "")
;          (setq zanting(getstring))
           (setq SS (ssget pt6))
        (ROTATE3D SS PT5 qidian FD )
  (setq PT pta)
                   (SETQ SL (- SL 1))
    (COMMAND "ERASE" PT "")
(defun C:3DLW ()
    (arxload "geom3d.ARX" NIL)
(shuru)
(SETQ SSs (GETvar "OSMODE"))
   (SETvar "OSMODE" 0)
        (SETQ SNM (GETvar "SNAPMODE"))
          (SETvar "SNAPMODE" 0)
        (SETQ PICKB (GETvar "PICKBOX"))
          (SETvar "PICKBOX" 0)
(setq cmd (getvar "cmdecho"))
   (setvar "cmdecho" 0)
        (JISUAN)
(SETQ GD (* 60 ZHIJING))
        (SETQ CT (POLAR QIDIAN PI (* LUOJU QUANSHU)))
(COMMAND "ZOOM" "C" CT GD)
        (draw)
   (SETvar "OSMODE" SSs)
   (setvar "cmdecho" cmd)
          (SETvar "SNAPMODE" SNM)
          (SETvar "PICKBOX" PICKB)
(princ "\n\tC: 3DLW 为绘制命令")
(princ)
发表于 2004-7-16 21:42:54 | 显示全部楼层
去试试看
发表于 2004-7-17 03:13:26 | 显示全部楼层
好长的一段,看不太懂
开始的时候就说了要用拉伸路径的方法画弹簧
我连路径的画法都没有想出来
郁闷中
GMT+8, 2026-10-18 10:40 , Processed in 0.446508 second(s), 34 queries , Gzip On.
