查看: 3633|回复: 5
[试用]:晓东工具箱-“区域拷贝”、“区域删除”提供...
发表于 2002-12-8 21:11:25 | 显示全部楼层 |阅读模式
“区域拷贝”
下载地址:http://www.xdcad.net/tech/xd_tbox/xdtb_regioncopy.swf
<embed src=http://www.xdcad.net/tech/xd_tbox/xdtb_regioncopy.swf quality=high width=512 height=482 loop=true type="application/x-shockwave-flash">
</embed>
“区域删除”
下载地址:http://www.xdcad.net/tech/xd_tbox/xdtb_regionerase.swf
<embed src=http://www.xdcad.net/tech/xd_tbox/xdtb_regionerase.swf quality=high width=512 height=482 loop=true type="application/x-shockwave-flash">
</embed>
  1. [font=courier new]
  2. ;|
  3.    命令:XDTB_RegionCopy
  4.    功能:区域拷贝
  5. |;
  6. (defun c:XDTB_RegionCopy (/ tf e filler box ss)
  7.   (if (not $XDTB_Global_Region_type)
  8.     (setq $XDTB_Global_Region_type "2")
  9.   )
  10.   (setq tf t)
  11.   (while (and
  12.            tf
  13.            (progn
  14.              (prompt (strcat "\n**操作方式--" (if (= $XDTB_Global_Region_type
  15.                                                   "1"
  16.                                                )
  17.                                              "窗口**"
  18.                                              "交叉窗口**"
  19.                                            )
  20.                      )
  21.              )
  22.              (initget "1 2")
  23.              (setq e (xdrx_entsel "\n请拾取区域的边界曲线[1:窗口/2:交叉]<退出>:"))
  24.            )
  25.            (progn
  26.              (cond
  27.                ((= (type e) 'STR)
  28.                  (setq $XDTB_Global_Region_type e)
  29.                )
  30.                ((= (type (car e)) 'ENAME)
  31.                  (setq tf nil)
  32.                )
  33.              )
  34.              t
  35.            )
  36.          )
  37.   )
  38.   (setq e (car e))
  39.   (if (>= (length (setq box (xdrx_getsamplept e))) 3)
  40.     (progn
  41.       (if (= $XDTB_Global_Region_type "1")
  42.         (setq filler (list "wp" box))
  43.         (setq filler (list "cp" box))
  44.       )
  45.       (if (setq ss (apply 'ssget filler))
  46.         (progn
  47.           (xdrx_begin)
  48.           (if (not (ssmemb e ss))
  49.             (ssadd e ss)
  50.           )
  51.           ($xdlsp_dragm ss nil t)
  52.           (xdrx_end)
  53.         )
  54.       )
  55.     )
  56.   )
  57.   (princ)
  58. )
  59. ;|
  60.    命令:XDTB_RegionErase
  61.    功能:区域删除
  62. |;
  63. (defun c:XDTB_RegionErase (/ tf e filler box ss)
  64.   (if (not $XDTB_Global_Region_Erase_type)
  65.     (setq $XDTB_Global_Region_Erase_type "2")
  66.   )
  67.   (setq tf t)
  68.   (while (and
  69.            tf
  70.            (progn
  71.              (prompt (strcat "\n**操作方式--" (if (= $XDTB_Global_Region_Erase_type
  72.                                                   "1"
  73.                                                )
  74.                                              "窗口**"
  75.                                              "交叉窗口**"
  76.                                            )
  77.                      )
  78.              )
  79.              (initget "1 2")
  80.              (setq e (xdrx_entsel "\n请拾取区域的边界曲线[1:窗口/2:交叉]<退出>:"))
  81.            )
  82.            (progn
  83.              (cond
  84.                ((= (type e) 'STR)
  85.                  (setq $XDTB_Global_Region_Erase_type e)
  86.                )
  87.                ((= (type (car e)) 'ENAME)
  88.                  (setq tf nil)
  89.                )
  90.              )
  91.              t
  92.            )
  93.          )
  94.   )
  95.   (setq e (car e))
  96.   (if (>= (length (setq box (xdrx_getsamplept e))) 3)
  97.     (progn
  98.       (if (= $XDTB_Global_Region_Erase_type "1")
  99.         (setq filler (list "wp" box))
  100.         (setq filler (list "cp" box))
  101.       )
  102.       (if (setq ss (apply 'ssget filler))
  103.         (progn
  104.           (xdrx_begin)
  105.           (if (ssmemb e ss)
  106.             (ssdel e ss)
  107.           )
  108.           (command ".erase" ss "")
  109.           (xdrx_end)
  110.         )
  111.       )
  112.     )
  113.   )
  114.   (princ)
  115. )
  116. [/font]
发表于 2002-12-9 00:47:33 | 显示全部楼层
太好了~~~~~~
发表于 2002-12-9 11:03:07 | 显示全部楼层
区域拷贝的內容好像有錯誤使用後出現...Command: XDTB_RegionCopy
**操作方式--交叉窗口**
?拾取?域的?界曲?[1:窗口/2:交叉]<退出>:; error: no function definition:
$XDLSP_DRAGM
Command:
 楼主| 发表于 2002-12-9 12:35:02 | 显示全部楼层
最初由 skevin1 发布
[B]区域拷贝的內容好像有錯誤使用後出現...Command: XDTB_RegionCopy
**操作方式--交叉窗口**
$XDLSP_DRAGM
Command: [/B]
在晓东工具箱环境下面使用。
发表于 2002-12-9 20:11:21 | 显示全部楼层
能不能单独写一个“选择”的程序,无论执行什么命令,在选择的时候都可以把曲线作为选择边界进行操作。现在cad中的命令中有选择有“wp”和“cp”,但没有选曲线实体方便。
发表于 2002-12-9 21:22:41 | 显示全部楼层
从上
一路到  (if (setq ss (apply 'ssget filler))
这ss酒丝
GMT+8, 2026-11-23 17:38 , Processed in 0.265818 second(s), 20 queries , Gzip On, File On.
