查看: 2697|回复: 2
[求助]:有个问题:AcDbViewTableRecord对象如何记录是在ModelSpace还是PaperSpace中?
发表于 2002-2-20 18:02:07 | 显示全部楼层 |阅读模式
发表于 2002-2-20 23:21:21 | 显示全部楼层
Re: [求助]:有个问题:AcDbViewTableRecord对象如何记录是在ModelSpace还是PaperSpace中?
最初由 e2002 发布
[B]AcDbViewTableRecord对象如何记录是在ModelSpace还是PaperSpace中? [/B]
ARX的AcDbViewTableRecord类有方法:
bool
isPaperspaceView() const;
Returns true if this ViewTableRecord is a Paper Space view. Otherwise it returns false.
Within AutoCAD, if a Paper Space view is restored while in Model Space, AutoCAD automatically switches to Paper Space. If a Model Space view is restored while in PaperSpace, AutoCAD prompts the end user to determine which Model Space viewport to restore it to.
The isPaperSpaceView flag is represented as bit 1 of DXF group code 70 (if bit 1 is set, then the view is a Paper Space view).
若用LISP可以参见上面说的组码70
发表于 2002-2-20 23:24:05 | 显示全部楼层
最初由 e2002 发布
设置一个AcDbViewTableRecord到图纸空间,可以使用
void
setIsPaperspaceView(
    bool pspace);
pspace        Input bool indicating whether or not this ViewTableRecord is a Paper Space view
If pspace == true, then the ViewTableRecord is set to be a Paper Space view. If pspace == false, then the ViewTableRecord is set to be a Model Space view.
或者entmod 对象的组码70
GMT+8, 2026-11-22 08:54 , Processed in 0.182422 second(s), 15 queries , Gzip On, File On.
