查看: 1201|回复: 1
[LISP程序]:配置(布局)排序
发表于 2002-2-22 08:22:53 | 显示全部楼层 |阅读模式
  1. ;;;配置(布局)排序
  2. ;;;程序设计:赖云龙;;;
  3. ;;;---------------;;;
  4. (defun C:LAYOUT_SORT (/ OBJDICT GRPDICT OUTLIST KEY SL N NN BB A3)
  5.   (setq OBJDICT (namedobjdict))
  6.   (setq GRPDICT (dictsearch OBJDICT "ACAD_LAYOUT"))
  7.   (setq KEY (getstring "\n大至小<L>/<小至大>: "))
  8.   (if (= KEY "")
  9.     (setq OUTLIST (acad_strlsort (layoutlist)))
  10.     (setq OUTLIST (reverse (acad_strlsort (layoutlist))))
  11.   )
  12.   (setq SL (length OUTLIST))
  13.   (setq NN 0)
  14.   (repeat SL
  15.     (setq BB (nth NN OUTLIST))
  16.     (setq N 2)
  17.     (while (/= (cdr (assoc 1
  18.                            (vl-member-if
  19.                              '(lambda (X) (= (cdr X) "AcDbLayout"))
  20.                              (entget (cdr (nth (+ 9 N) GRPDICT)))
  21.                            )
  22.                     )
  23.                )
  24.                BB
  25.            )
  26.       (setq N (+ 2 N))
  27.     )
  28.     (setq A3 (entget (cdr (nth (+ 9 N) GRPDICT))))
  29.     (setq A3 (subst (cons 71 (+ 1 NN)) (assoc 71 A3) A3))
  30.     (entmod A3)
  31.     (setq NN (1+ NN))
  32.   )
  33.   (command "_.regen")
  34.   (princ)
  35. )
  1. ;;;删除空白配置(布局)更新
  2. ;;;程序设计:赖云龙;;;
  4. (defun C:LAYOUT_DEL (/ HOLDECHO OUTLIST SL N LAYOUT_NAME A)
  5.   (setq HOLDECHO (getvar "CMDECHO"))
  6.   (setvar "CMDECHO" 0)
  7.   (setq OUTLIST (LAYOUTLIST))
  8.   (setq SL (length OUTLIST))
  9.   (setq N 0)
  10.   (repeat SL
  11.     (setq LAYOUT_NAME (nth N OUTLIST))
  12.     (setq A (ssget "X" (list (cons 410 LAYOUT_NAME))))
  13.     (if        (or (= NIL A) (= (sslength A) 1))
  14.       (command "_.layout" "delete" LAYOUT_NAME)
  15.     )
  16.     (setq N (1+ N))
  17.   )
  18.   (setvar "CMDECHO" HOLDECHO)
  19.   (princ)
  20. )
发表于 2005-2-18 08:46:21 | 显示全部楼层
ACAD本身就能实现这样的功能
GMT+8, 2026-11-3 13:44 , Processed in 0.413307 second(s), 34 queries , Gzip On.
