查看: 962|回复: 5
[原创]:另类图元隐藏/显示,通过建立组隐藏实体
已领礼包: 593个
发表于 2004-8-16 12:19:07 | 显示全部楼层 |阅读模式
  1. ;;另类图元隐藏/显示,通过建立组隐藏实体
  2. ;|
  3. visible
  4. object.Visible
  5. object
  6.       All Drawing objects, Application, AttributeReference, Group, Toolbar
  7.       The object or objects this property applies to.
  8. Boolean; read-write (write-only for the Group object)
  9. TRUE:    The object or application is visible.
  10. FALSE:   The object or application is not visible.
  11. Remarks
  12. If you specify an object to be invisible, it will be invisible regardless of
  13. the application visible setting. Other factors can also cause an object to be
  14. invisible; for example, an objectwill not be displayed if its layer is off or
  15. frozen.
  16. Specifying the application to be invisible allows you to run tasks in the
  17. background without having to see the component.
  18. Specifies the visibility of an object or the application.
  19. All Drawing objects, Application, AttributeReference, Group, Toolbar
  20. |;
  21. (defun ea:SSonoff (tf s mode / groups gl)
  22.   (setvar "cmdecho" 0)
  23.   ;;检测是否有特定组
  24.   (if (vl-catch-all-error-p
  25.         (vl-catch-all-apply
  26.           'vla-item
  27.           (list
  28.             (setq
  29.               groups
  30.                (vla-get-groups
  31.                  (vla-get-activedocument (vlax-get-acad-object))
  32.                )
  33.             )
  34.             "ea_hide_object"
  35.           )
  36.         )
  37.       )
  38.     (progn
  39.       (setq gr (vla-add groups "ea_hide_object"));添加组
  40.       (setq gl (entget (vlax-vla-object->ename gr)))
  41.       (entmod (subst '(71 . 0)
  42.                      (assoc 71 gl)
  43.                      gl
  44.               )
  45.       );不可选择
  46.     );end progn
  47.   );end if
  48.   (if (not tf)
  49.     (progn
  50.       (command ".select" "all" "r" s "")
  51.       (command ".group" "a" "ea_hide_object" "p" "")
  52.     );隔离隐藏用
  53.     (command ".group" "a" "ea_hide_object" s "")
  54.   )
  55.   (vla-put-visible
  56.     (vla-item groups "ea_hide_object")
  57.     mode
  58.   );隐藏组,实体将不拥有 62 组码
  59.   (princ)
  60. )
  61. ;;隐藏选择实体
  62. (defun c:Hideobj (/ ss)
  63.   (if (progn (princ "\n选择要隐藏的实体...")
  64.              (setq ss (ssget))
  65.       )
  66.     (ea:SSonoff t ss :vlax-false)
  67.   )
  68.   (princ)
  69. )
  70. ;;显示全部实体
  71. (defun c:Showall (/ ss)
  72.   (setvar "pickstyle" 0)
  73.   (if (not (vl-catch-all-error-p
  74.              (vl-catch-all-apply
  75.                'vla-item
  76.                (list
  77.                  (setq
  78.                    groups
  79.                     (vla-get-groups
  80.                       (vla-get-activedocument (vlax-get-acad-object))
  81.                     )
  82.                  )
  83.                  "ea_hide_object"
  84.                )
  85.              )
  86.            )
  87.       )
  88.     (progn
  89.       (vla-put-visible
  90.         (vla-item groups "ea_hide_object")
  91.         :vlax-true
  92.       )
  93.       (command ".group" "e" "ea_hide_object");清除组
  94.     )
  95.   )
  96.   (princ)
  97. )
  98. ;;隐藏非选择实体
  99. (defun c:ISOobj        (/ ss)
  100.   (if (progn (princ "\n选择隔离实体....")
  101.              (setq ss (ssget))
  102.       )
  103.     (ea:ssonoff nil ss :vlax-false)
  104.   )
  105.   (princ)
  106. )
  107. (princ "\n\t命令: HideObj ShowAll IsoObj.")
发表于 2004-8-17 16:32:05 | 显示全部楼层
太好了,谢谢班竹!!!!,极力推荐!!!!!
请问(defun ea:SSonoff (tf s mode / groups gl)
中的ea:是什么意思,以及它的用法??
试用了一下,有一个问题就是如果图形文件较大或对象较多时运行起来就比较慢了[/COLOR]
发表于 2004-8-17 23:39:28 | 显示全部楼层
ea:大概就是eachy的意思了,ea:SSonoff 就是一个自定义函数。
发表于 2004-8-19 08:23:47 | 显示全部楼层
请问楼主,这种功能你在什么情况用?我觉得好象用不到啊
发表于 2004-8-20 10:31:37 | 显示全部楼层
楼主,真是太好用!
什么都能隐藏,请问为什么说“通过建立组隐藏实体 ”?
不用建立组吧!
虽然是为了控制方便!
发表于 2004-8-22 21:52:12 | 显示全部楼层
請問命令是什麼丫,小弟不懂lsp指令說
GMT+8, 2026-11-5 02:57 , Processed in 0.529118 second(s), 42 queries , Gzip On.
