查看: 2377|回复: 11
[LISP程序]:直击-弧长标注
发表于 2002-2-28 15:43:33 | 显示全部楼层 |阅读模式
beta0.1测试版本
简介:
本程序不是标角度,而是用于标弧长的。
1.dmarc,单段圆弧标注
2.dimarc,圆弧连续标注;对圆分段标注也有效果
  1. [font=courier new]
  2. (princ "\ndmarc=====dim arc 单段圆弧标注--------lxx.2001.5")
  3. (princ "\ndimarc=====dim arc 圆弧连续标注--------lxx.2001.5")
  4. ;;=============================================================
  5. (defun c:dmarc (/ n ent entl rad ans ane ptcen pts pte ang arcl)
  6. (princ "\ndim arc 单段圆弧标注--------lxx.2001.5")
  7. (setq n (getint "\n标注文字小数点后位数<2>:"))
  8. (if (not n) (setq n 2))
  9. (setq ent (car(entsel "\n选择圆弧:"))
  10.       entl (entget ent)
  11.       rad (cdr (assoc 40 entl))
  12.       ans (cdr (assoc 50 entl))
  13.       ane (cdr (assoc 51 entl))
  14.       ptcen (cdr (assoc 10 entl))
  15.       pts (polar ptcen ans rad)
  16.       pte (polar ptcen ane rad)
  17. )
  18. (if (> ane ans)
  19.     (setq ang (- ane ans))
  20.     (setq ang (+ ane (- (* 2 PI) ans)))
  21. )
  22. (setq arcl (rtos (* rad ang) 2 n))
  23. (command "dim" "an" "" ptcen pts pte pause arcl "" "e")
  24. (princ)
  25. )
  26. ;;=============================================================
  27. (defun c:dimarc (/ n ent entl rad ptcen roop ptoff pts pte ans ane roff ang arcl)
  28. (princ "\ndim arc 圆弧连续标注--------lxx.2001.5")
  29. (setq n (getint "\n标注文字小数点后位数<2>:"))
  30. (if (not n) (setq n 2))
  31. (setq ent (car(entsel "\n选择圆弧:"))
  32.       entl (entget ent)
  33.       rad (cdr (assoc 40 entl))
  34.       ptcen (cdr (assoc 10 entl))
  35.       roop "true"
  36.       ptoff (getpoint "\n标注延伸线偏移点:")
  37. )
  38. (getarcl)
  39. (command "dim" "an" "" ptcen pts pte pause arcl "")
  40. (while roop
  41. (getarcl)
  42. (if (not pte)
  43.      (setq roop nil)
  44.      (progn
  45.       (command "co" pte)
  46.       (setq entl (entget(entlast))
  47.             entl (subst (cons 1 arcl) (assoc 1 entl) entl)
  48.       )
  49.       (entmod entl)
  50.      );end progn
  51. )
  52. );;end while
  53. (command)
  54. (princ)
  55. )
  56. ;;getarcl
  57. (defun getarcl ()
  58. (if (not pts) (setq pts (getpoint "\n标注起点:")) )
  59. (if pte (setq pts pte))
  60. (setq pte (getpoint "\n标注终点:")
  61.       ans (angle ptcen pts)
  62.       ane (angle ptcen pte)
  63. )
  64. (if ptoff (setq roff (distance ptcen ptoff);;;;;;;标注美化
  65.                 pts (polar ptcen ans roff)
  66.                 pte (polar ptcen ane roff)
  67.           )
  68. )
  69. (if (> ane ans)
  70.     (setq ang (- ane ans))
  71.     (setq ang (+ ane (- (* 2 PI) ans)))
  72. )
  73. (setq arcl (rtos (* rad ang) 2 n))
  74. )
  75. [/font]
发表于 2002-3-1 07:56:36 | 显示全部楼层
请问代码是如何贴上去的,有一条灰色的分隔线。
而且格式保持很好。
程序没有细看,能作个针对弧线的break吗?
已领礼包: 145个
发表于 2002-3-1 11:26:56 | 显示全部楼层
最初由 goodsheep 发布
[B]请问代码是如何贴上去的,有一条灰色的分隔线。
而且格式保持很好。
程序没有细看,能作个针对弧线的break吗? [/B]
返回论坛,看置顶的帖子“论坛上贴代码保持格式缩进的方法”
说说你说的针对ARC的BREAK是什么要求吧?
发表于 2003-5-8 23:35:29 | 显示全部楼层
此程序不能判断是优弧还是劣弧,是严重的缺陷,请各位引用者注意。
发表于 2003-5-30 06:44:09 | 显示全部楼层
有一个更简捷的小程序, 见AutoLisp/Vlisp技术开发专栏.
发表于 2004-8-7 22:30:04 | 显示全部楼层
厉害!!!!!!!
发表于 2004-8-8 23:35:56 | 显示全部楼层
我还没用呢
不知道哪里有更有好的程序
发表于 2004-8-21 22:38:48 | 显示全部楼层
试着判断了优弧劣弧问题,可以在14下运行!
  1. (defun set_ini ()
  2.   (setq cmdsave (getvar "cmdecho"))
  3.   (setq os (getvar "OSMODE"))
  4.   (setvar "cmdecho" 0)
  5.   (setvar "OSMODE" 0)
  6. ) ;_ end of defun
  7. (defun err_new (msg) (princ msg) (set_close)) ;_ end of defun
  8. (defun set_close ()
  9.   (setvar "OSMODE" os)
  10.   (setvar "cmdecho" cmdsave)
  11.   (setq *error* err_old)
  12. ) ;_ end of defun
  13. (defun c:dimarc        (/ n key os cmdsave err_old)
  14.   (setq        err_old        *error*
  15.         *error*        err_new
  16.   ) ;_ end of setq
  17.   (set_ini)
  18.   (initget 128 "S C")
  19.   (setq key (getkword "\n[单段圆弧标注(S)/圆弧连续标注(C)]< S >: "))   (if (/= key nil)
  20.     (setq key (strcase key))
  21.   ) ;_ end of if
  22.   (if (or (= key "S") (= key nil))
  23.     (dimarc_s)
  24.     (if        (= key "C")
  25.       (dimarc_C)
  26.     )
  27.   )
  28.   (set_close)
  29.   (gc)
  30.   (princ)
  31. )
  32. (defun dimarc_s        (/ ent entl rad ans ane ptcen pts pte)
  33.   (setq n (getint "\n标注文字小数点后位数<2>:"))
  34.   (if (not n)
  35.     (setq n 2)
  36.   )
  37.   (setq        ent   (car (entsel "\n选择圆弧:"))
  38.         entl  (entget ent)
  39.         rad   (cdr (assoc 40 entl))
  40.         ans   (cdr (assoc 50 entl))
  41.         ane   (cdr (assoc 51 entl))
  42.         ptcen (cdr (assoc 10 entl))
  43.         pts   (polar ptcen ans rad)
  44.         pte   (polar ptcen ane rad)
  45.   )
  46.   (command "dim" "an" "" ptcen pts pte pause "" "" "e")
  47.   (ang2len)
  48.   (princ)
  49. )
  50. ;;=============================================================
  51. (defun dimarc_c        (/ ent entL rad ptcen roop pts pte)
  52.   (setq n (getint "\n标注文字小数点后位数<2>:"))
  53.   (if (not n)
  54.     (setq n 2)
  55.   )
  56.   (setq        ent   (car (entsel "\n选择圆弧:"))
  57.         entL  (entget ent)
  58.         rad   (cdr (assoc 40 entL))
  59.         ptcen (cdr (assoc 10 entL))
  60.         roop  "true"
  61.   )
  62.   (getarcL)
  63.   (command "dim" "an" "" ptcen pts pte pause "" "")
  64.   (ang2len)
  65.   (while roop
  66.     (getarcL)
  67.     (if        (not pte)
  68.       (setq roop nil)
  69.       (progn (command "co" pte) (ang2len)) ;end progn
  70.     )
  71.   )
  72.   ;;end while
  73.   (princ)
  74. )
  75. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  76. (defun getarcL ()
  77.   (setvar "OSMODE" 33)
  78.   (if (not pts)
  79.     (setq pts (getpoint "\n标注起点:"))
  80.   )
  81.   (if pte
  82.     (setq pts pte)
  83.   )
  84.   (setq pte (getpoint "\n标注终点: <右键结束圆弧标注>"))
  85.   (if (= pte nil)
  86.     (command "dim" "e")
  87.   )
  88. )
  89. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  90. (defun ang2len (/ entL ang arcL        ptcen pts pte ptp ang01        ang02 ang03
  91.                 ang21 ang31)
  92.   (setq        entL  (entget (entLast))
  93.         ptcen (cdr (assoc 15 entL))
  94.         pts   (cdr (assoc 13 entL))
  95.         pte   (cdr (assoc 14 entL))
  96.         ptp   (cdr (assoc 10 entL))
  97.         ang01 (angle ptcen pts)
  98.         ang02 (angle ptcen pte)
  99.         ang03 (angle ptcen ptp)
  100.         ang21 (- ang02 ang01)
  101.         ang31 (- ang03 ang01)
  102.   )
  103.   (if (<= ang21 0)
  104.     (if        (< ang31 ang21)
  105.       (setq ang (+ (* pi 2) ang21))
  106.       (if (> ang31 0)
  107.         (setq ang (+ (* pi 2) ang21))
  108.         (setq ang (- ang21))
  109.       )
  110.     )
  111.     (if        (< ang31 ang21)
  112.       (if (< ang31 0)
  113.         (setq ang (- (* pi 2) ang21))
  114.         (setq ang ang21)
  115.       )
  116.       (setq ang (- (* pi 2) ang21))
  117.     )
  118.   )
  119.   (setq        arcL (rtos (* rad ang) 2 n)
  120.         arcL (strcat "%%o" arcL)
  121.         entL (subst (cons 1 arcL) (assoc 1 entL) entL)
  122.   )
  123.   (entmod entL)
  124. )
发表于 2004-8-23 13:51:26 | 显示全部楼层
还是用标注角度的方法,没有加上弧长的标志,不符合国标啊?
发表于 2005-1-23 17:46:33 | 显示全部楼层
没有LISP的么
发表于 2005-2-15 23:31:37 | 显示全部楼层
还有很好的吗
发表于 2005-3-21 19:01:21 | 显示全部楼层
梦断江南:
谢谢您的好程序,解决了分段标注的问题,但如果能随层标注就更好了.但分段标注标注的尺寸好象不对,也许就是优弧与劣弧的问题吧?
GMT+8, 2026-11-3 07:26 , Processed in 0.589105 second(s), 54 queries , Gzip On.
