查看: 1133|回复: 2
[讨论]:关于自动运行ARX命令
发表于 2004-8-26 17:05:11 | 显示全部楼层 |阅读模式
关于自动运行ARX命令
//在initApp中注册了autorun命令
void initApp()
  acedRegCmds->addCommand( "MKEvents",      // Group name
                           "autorun",      // Global function name
                           "autorun",          // Local function name
                           ACRX_CMD_MODAL,    // Type
                           &autorun );         // Function pointer
//并且用acedCommand执行autorun命令
acedCommand(RTSTR,"autorun",0);
把生成的ARX文件加入启动组,请问各位大侠为什么AUTOCAD启动时 "autorun"不执行?
但AUTOCAD启动后 手动加载"autorun"却可以执行!??
发表于 2004-8-26 23:17:45 | 显示全部楼层
acedCommand()........
1). Do not use acedCommand() in functions registered as ACRX_CMD_TRANSPARENT
2). Do not use acedCommand() to execute any other commands registered via acedRegCmds->addCommand() [/COLOR]
3). Do not use acedCommand() to execute anything that will allow user interaction
 楼主| 发表于 2004-8-27 13:45:05 | 显示全部楼层
2楼楼主所指出的和1楼所说不是一个问题!
The acedCommand() function supports re-entrance up to four levels deep. ......
"If you must use acedCommand() in functions registered via acedRegCmds->addCommand(), you can avoid exceeding the re-entry limit of four levels, if you:
1. Do not use acedCommand() in functions registered as ACRX_CMD_TRANSPARENT
2. Do not use acedCommand() to execute any other commands registered via acedRegCmds->addCommand()
3. Do not use acedCommand() to execute anything that will allow user interaction "
以上内容根据原上下文,我的理解是:
假如你一定要在 由acedRegCmds->addCommand()注册的函数中使用acedCommand(), 你可以避免
函数重入最多4级嵌套的限制,只要做到以下三点:
        1. 不要在 以透明命令方式注册的函数中使用acedCommand()。
        2. 不要在使用acedCommand()去执行其它由acedRegCmds->addCommand()注册的命令。
        3. 不要在使用acedCommand()去执行任何允许用户交互的函数。
关于自动运行ARX命令是不是没有重入的问题???
GMT+8, 2026-11-6 21:01 , Processed in 0.452746 second(s), 36 queries , Gzip On.
