查看: 1093|回复: 1
[LISP程序]:cad视图工具----增强的 vpoint
发表于 2002-12-28 19:24:21 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. ;增强的 vpoint
  3. (defun c:lxxvp (/ ang1 ang2 id k)
  4. (command "ucs" "world")
  5. (command "vpoint" "1,-1,1")
  6.   (setq p0 (getpoint "\n 2点定xy平面角,1st pt:")
  7.         ang1 (angtos (getangle p0 "\n2nd pt:") 0 0)
  8.         ang2 (angtos (getangle p0 "\n 2点定camera与xy平面夹角,2nd pt:") 0 0)
  9.         id 1)
  10.   (command "vpoint" "r" ang1 ang2)
  11.   (while (/= id 0)
  12.      (setq k (getstring "\n6/8/4/2<eXit>:"))
  13.      (cond
  14.           ((= k "6")(setq ang1 (rtos (+ (atoi ang1) 5))))
  15.           ((= k "8")(setq ang2 (rtos (+ (atoi ang2) 5))))
  16.             ((= k "4")(setq ang1 (rtos (- (atoi ang1) 5))))
  17.           ((= k "2")(setq ang2 (rtos (- (atoi ang2) 5))))
  18.           ((= k "")(setq id 0))
  19.      )
  20.      (command "vpoint" "r" ang1 ang2)
  21.   )
  22. )
  23. ;;;
  24. (princ "\n -------lxxvp---------   lxx-2000.02.11")
  25.   [/FONT]
发表于 2006-5-20 19:42:16 | 显示全部楼层
好像没什么用
GMT+8, 2026-11-3 01:52 , Processed in 0.595135 second(s), 33 queries , Gzip On.
