查看: 852|回复: 0
[LISP程序]:文本工具:文字序号增值
发表于 2002-12-28 22:06:48 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. (princ "\ntadd====txt add 文字序号增值 -----------lxx.2001.7")
  3. (defun c:tadd ()
  4.   (princ "\ntadd====txt add 文字序号增值-----------lxx.2001.7")
  5.   (setq ss (ssget '((0 . "TEXT")))
  6.         nadd (getint "\n增加值<1>:")
  7.         dec (getint "\n精度<0>:")
  8.         i 0)
  9.   (if (not nadd)(setq nadd 1))
  10.   (if (not dec)(setq dec 0))
  11.   (repeat (sslength ss)
  12.     (setq ent (ssname ss i)
  13.           entl (entget ent)
  14.           i (1+ i)
  15.     )
  16.     (txtadd entl nadd dec)
  17.   )
  18.   (princ)
  19. )
  20. ;;;;;txtadd
  21. (defun txtadd (entl nadd dec /)
  22.   (setq        bnam0 (cdr(assoc 1 entl)));;;old txt
  23.   (princ "\n原字串:")(princ bnam0)
  24.   ;;使得序号不重复
  25.   (setq nlen (strlen bnam0)
  26.         n1 1
  27.         lastn nil)
  28.   (while (and (/= 0 nlen)(member (substr bnam0 nlen 1) '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9" ".")))
  29.         (setq lastn (atof (substr bnam0 nlen n1));;字串尾序号
  30.               nlen (1- nlen)
  31.               n1 (1+ n1)
  32.         )
  33.   );;end while
  34.   (if lastn;;;;;;;;确定新字串---尾序号累加nadd,无序号加nadd
  35.    (progn (setq lastn (+ lastn nadd))
  36.           (if (or (= 'INT (type (read bnam0))) (= 'REAL (type (read bnam0))));;当字串如"3"
  37.               (setq bnam (rtos lastn 2 dec))
  38.               (setq bnam (strcat (substr bnam0 1 nlen) (rtos lastn 2 dec)))
  39.           )
  40.    )
  41.    (progn (setq lastn nadd)         ;;else
  42.           (if (or (= 'INT (type (read bnam0)))(= 'REAL (type (read bnam0))))
  43.               (setq bnam (rtos lastn 2 dec))
  44.               (setq bnam (strcat bnam0 (rtos lastn 2 dec)))
  45.           )
  46.    )
  47.   );;end if
  48.   (princ " 改为:")(princ bnam)
  49.   (setq entl (subst (cons 1 bnam) (assoc 1 entl) entl))
  50.   (entmod entl)(entupd ent)
  51. )
  52.
  53.
  54.
  55.
  56.   [/FONT]
GMT+8, 2026-11-3 15:05 , Processed in 0.675804 second(s), 32 queries , Gzip On.
