查看: 1000|回复: 1
[求助]:帮忙粘个microstation自带的简化命令
发表于 2004-8-30 11:05:34 | 显示全部楼层 |阅读模式
我不知道怎么找那些自带的命令。我要现看看这些命令,在来设置适合我的命令。谁帮我一下。。谢谢。
除了,shortcut里面的就没有了?
Enter        "Smart Lock"        "AccuDraw Lock Smart"
Space        "Change Mode"        "AccuDraw Mode"
O        "Set Origin"        "AccuDraw SetOrigin"
V        "View Rotation"        "AccuDraw Rotate View"
T        "Top Rotation"        "AccuDraw Rotate Top"
F        "Front Rotation"        "AccuDraw Rotate Front"        3D
S        "Side Rotation"        "AccuDraw Rotate Side"        3D
B        "Base Rotation"        "AccuDraw Rotate Base Toggle"
E        "Cycle Rotation"        "AccuDraw Rotate Cycle"        3D
X        "Lock X"        "AccuDraw Lock X"
Y        "Lock Y"        "AccuDraw Lock Y"
Z        "Lock Z"        "AccuDraw Lock Z"        3D
D        "Lock Distance"        "AccuDraw Lock Distance"
A        "Lock Angle"        "AccuDraw Lock Angle"
L        "Lock Index"        "AccuDraw Lock Index"
RQ        "Rotate Quick"        "AccuDraw Rotate Quick"
RA        "Rotate ACS"        "AccuDraw Rotate ACS"
RX        "Rotate about X"        "AccuDraw Rotate X"        3D
RY        "Rotate about Y"        "AccuDraw Rotate Y"        3D
RZ        "Rotate about Z"        "AccuDraw Rotate Z"
?        "Show Shortcuts"        "AccuDraw Dialog Shortcuts"
~        "Bump Tool Setting"        "AccuDraw Bump ToolSetting"
GT        "Go to Tool Settings"        "Dialog ToolSetting"
GK        "Go to Keyin"        "Dialog CmdBrowse"
GS        "Go to Settings"        "AccuDraw Dialog Settings"
GA        "Get ACS"        "AccuDraw Dialog GetACS"
WA        "Write to ACS"        "AccuDraw Dialog SaveACS"
P        "Point Keyin (single)"        "Point Keyin Single"
I        "Intersect Snap"        "Snap Intersect"
N        "Nearest Snap"        "Snap Nearest"
C        "Center Snap"        "Snap Center"
K        "Snap Divisor"        "AccuDraw Dialog SnapDivisor"
U        "Suspend AccuSnap"        "AccuSnap Suspend"
J        "Toggle AccuSnap"        "AccuSnap Toggle"
Q        "Quit AccuDraw"        "Accudraw Quit"
CO        "copy extended "        "copy extended "
发表于 2004-8-30 13:40:43 | 显示全部楼层
用Utilities→Macro→Create BASIC Macro先录制一个您的操作,再打开这个MicroStation的BASIC宏,从中能得到您想要的键入命令。
刚写完答复发现理解错了您的意思,您要的是命令的简写形式。但您所附的并非MS的简写命令,它们是启动AccuDraw后的AccuDraw的简写命令。致于MS的简写命令均为两个字母后跟一等号,等号后面可写需要的参数。如:
KY=   (设置等分个数)
LC=   (设置线型)
WT=  (设置线宽)
CO=  (设置颜色)
AS=  (设置激活比例,X/Y/Z相等)
XS=  (设置X激活比例)
YS=   (设置Y激活比例)
ZS=   (设置Z激活比例)
TX=  (设置文字大小,宽高相同)
TH=  (设置字高)
TW= (设置字宽)
FT=  (设置字体)
FF=  (把Fence中的内容写入一新的DGN文件中,保留当前Fence中的内容)
SF=  (把Fence中的内容写入一新的DGN文件中,不保留当前Fence中的内容)
这类简写命令还有许多......
GMT+8, 2026-11-22 10:00 , Processed in 0.141590 second(s), 12 queries , Gzip On, File On.
