查看: 867|回复: 0
[分享]:打造AUTOCAD 的宏命令
发表于 2004-9-3 16:51:55 | 显示全部楼层 |阅读模式
拜aidraft所赐的函数SendKeys,做几个调用文字修改大师的宏命令。觉得很有趣,请大家过目。
  1.   [FONT=courier new]
  2. ;;;;___________________________________________
  3. ;;;;___________________________________________
  4. ;;;;___________________________________________
  5. (defun SendKeys        (keys / ws)
  6.   (vl-load-com)
  7.   (setq ws (vlax-create-object "WScript.Shell"))
  8.   (vlax-invoke-method ws 'sendkeys keys)
  9.   (vlax-release-object ws)
  10.   (princ)
  11. )
  12. (defun ptos (e)
  13.     (setq e (mapcar 'rtos e))
  14.     (setq e (strcat (car e) "," (cadr e) "," (caddr e)))
  15.   )
  16. ;;;;___________________________________________
  17. ;;;;___________________________________________
  18. ;;;;___________________________________________
  19. (defun c:tt();;文字替换
  20.   (setq ss (ssget '((0 . "text"))))
  21.   (command "._select" ss "")
  22.   (setq str1 "77")
  23.   (setq str2 "88")
  24.   (sendkeys (strcat"ctt r   l " str1 " " str2 "  "))
  25.   )
  26. (defun c:tt();;文字打断
  27.   (setq e (cadr (entsel)))
  28.   (setq e (ptos  e))
  29.   (sendkeys (strcat"ctt n " e " " e "  "))
  30.   )
  31. (defun c:tt();;文字居中对齐
  32.     (princ "\n选择文字:")
  33.   (setq p1 (getpoint "\n角点1"))
  34.   (setq p2 (getcorner p1 "\对角点:"))
  35.   (setq p3 (getpoint  "\对齐点:"))
  36.   (setq p1 (ptos p1) p2 (ptos p2) p3(ptos p3) )
  37.   (sendkeys (strcat"ctt q " p1 " " p2 "  m c a c "p3"  "))
  38.   )
  39.   [/FONT]
GMT+8, 2026-11-5 10:11 , Processed in 0.406043 second(s), 32 queries , Gzip On.
