查看: 828|回复: 1
[LISP程序]:计算圆弧,线的总长度
发表于 2004-9-6 15:58:53 | 显示全部楼层 |阅读模式
;;;计算线加总长度
(defun C:ADDLEN (/ CURVE TLEN SS N SUMLEN)
  (vl-load-com)
  (setq SUMLEN 0)
  (setq SS (ssget '((0 . "CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC"))))
  (setq N 0)
  (repeat (sslength SS)
    (setq CURVE (vlax-ename->vla-object (ssname SS N)))
    (setq TLEN (vlax-curve-getdistatparam
CURVE
(vlax-curve-getendparam CURVE)
    (setq SUMLEN (+ SUMLEN TLEN))
    (setq N (1+ N))
  (print (strcat "总长度: " (rtos SUMLEN 2 5)))
  (princ)
发表于 2004-10-3 12:30:09 | 显示全部楼层
A2002下可以用吗?
GMT+8, 2026-11-5 10:09 , Processed in 0.406321 second(s), 33 queries , Gzip On.
