查看: 1044|回复: 2
[转贴]:可分类统计多曲线长度的程序
发表于 2004-9-15 10:34:46 | 显示全部楼层 |阅读模式
可分类统计多曲线长度的程序
[php]
;;; bomlenghts.lsp
;;; By Jimmy Bergmark
;;; Copyright (C) 1997-2004 JTB World, All Rights Reserved
;;; Website: www.jtbworld.com
;;; E-mail: info@jtbworld.com
;;; 1998-03-31 - First release
;;; 2000-05-11 - Fixed for LWPOLYLINES and for A2k
;;; 2003-06-10 - Tested on 2004 and fixed a minor bug
;;; 2004-03-18 - Added (vl-load-com)
;;; Tested on AutoCAD 2000, 2004, 2005
;;; should be working on older versions too with minor modifications.
;;;  exchange bom-code-old with bom-code
;;;  DESCRIPTION
;;;  BILL OF LENGHTS.
;;;  c:bomlengths - lenght of lines, arcs, polylines and splines and total.
;;;  c:bom_lines - lenght of lines and total.
;;;  c:bom_arcs - lenght of arcs, and total.
;;;  c:bom_polylines - lenght of polylines and total.
;;;  c:bom_splines - lenght of splines and total.
(defun dxf (n ed) (cdr (assoc n ed)))
(defun bom-code (ssfilter        /       errexit undox   restore
                 *error* olderr  oldcmdecho      %l      %t
                 sset    %i      en      ed      p1      p2
                 ot      a1      a2      r
  (defun errexit (s)
    (princ)
    (restore)
  (defun undox ()
    (command "._undo" "_E")
    (setvar "cmdecho" oldcmdecho)
    (setq *error* olderr)
    (princ)
  (setq olderr  *error*
        restore undox
        *error* errexit
  (setq oldcmdecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "._UNDO" "_BE")
  (setq %i 0
        %t 0
  (vl-load-com)
  (setq sset (ssget ssfilter))
  (if sset
    (progn
      (princ "\nLengths:")
      (repeat (sslength sset)
        (setq en (ssname sset %i))
        (setq ed (entget en))
        (setq ot (dxf 0 ed))
        (setq curve (vlax-ename->vla-object en))
        (if (vl-catch-all-error-p
              (setq len        (vl-catch-all-apply
                          'vlax-curve-getDistAtParam
                          (list        curve
                                (vl-catch-all-apply
                                  'vlax-curve-getEndParam
                                  (list curve)
          nil
          len
        (setq %l len)
        (setq %i (1+ %i)
              %t (+ %l %t)
        (terpri)
        (princ %l)
      (princ "\nTotal = ")
      (princ %t)
      (textpage)
  (restore)
(defun bom-code-old (ssfilter        /       errexit undox   restore
                 sset    %i      en      ed      p1      p2
                 ot      a1      a2      r
  (defun errexit (s)
    (princ)
    (restore)
  (defun undox ()
    (princ)
        restore undox
        *error* errexit
  (setq %i 0
        %t 0
  (if sset
    (progn
        (cond
          ((= ot "LINE")
           (setq p1 (dxf 10 ed)
                 p2 (dxf 11 ed)
                 %l (distance p1 p2)
          ((= ot "ARC")
           (setq a1 (dxf 50 ed)
                 a2 (dxf 51 ed)
                 r  (dxf 40 ed)
                 %l (* r (abs (- a2 a1)))
          (t
           (command "._area" "_obj" en)
           (setq %l (getvar "perimeter"))
        (setq %i (1+ %i)
              %t (+ %l %t)
        (terpri)
        (princ %l)
      (princ %t)
      (textpage)
  (restore)
(defun c:test ()
  (initget "Lines Arcs Polylines Splines ALL")
  (setq ans (getkword
              "Enter an option [Lines/Arcs/Polylines/Splines] <ALL>: "
  (cond
    ((= ans "Lines") (c:bom_lines))
    ((= ans "Arcs") (c:bom_arcs))
    ((= ans "Polylines") (c:bom_polylines))
    ((= ans "Splines") (c:bom_splines))
    (t
     (bom-code '((-4 . "<OR")
                 (0 . "LINE")
                 (0 . "ARC")
                 (0 . "POLYLINE")
                 (0 . "LWPOLYLINE")
                 (0 . "SPLINE")
                 (-4 . "OR>")
  (princ)
(defun c:bom_lines ()
  (bom-code '((0 . "LINE")))
  (princ)
(defun c:bom_arcs ()
  (bom-code '((0 . "ARC")))
  (princ)
(defun c:bom_polylines ()
              (0 . "POLYLINE")
              (0 . "LWPOLYLINE")
              (-4 . "OR>")
  (princ)
(defun c:bom_splines ()
  (bom-code '((0 . "SPLINE")))
  (princ)
[/php]
发表于 2004-9-21 12:33:38 | 显示全部楼层
謝謝了了了謝謝謝了了了謝謝
謝了了了了了謝了了了了了謝
謝了了了了了了了了了了了謝
謝了了真心地向您致敬了了謝
謝謝了了了謝謝谢了了了謝謝
謝謝謝了了了了了了了謝謝謝
謝謝謝謝了了了了了謝謝謝謝
謝謝謝謝謝了了了謝謝謝謝謝
謝謝謝謝謝謝了謝謝謝謝謝謝
发表于 2004-10-3 11:18:18 | 显示全部楼层
怎么用法?
谢谢指点
GMT+8, 2026-11-3 07:28 , Processed in 0.453389 second(s), 36 queries , Gzip On.
