查看: 803|回复: 6
[求助]:關於正航大大的一個程序
发表于 2004-9-17 09:27:05 | 显示全部楼层 |阅读模式
如果使它第一個選擇的目標顯亮?如果我只要替換一次文字,而不是批量修改,該如何修正?
;;本程序用目標文字替換需改變的文字。可以是TEXT和屬性塊中的屬性文字
(defun c:th1(/ a b ent ent2 elist etype oldval bltxt entdata btxt ostr pt oltxt )
(princ "\n ******* 文字替換程序 ******* Writen by 正航")
(princ "\n請選擇複製源文字目標:")
(setq ent (nentsel))
(if (= ent nil)(setq oldval (getstring "\n請輸入文字:"))
(progn
(setq ent2 ent elist (entget (car ent)) etype (cdr (assoc 0 elist))
(setq oldval (cdr (assoc 1 elist)))
(princ "\n ")
(princ "\n複製文字內容為: ") (princ oldval)
(setq q 9)
(while q
(princ "\n ")
(setq bltxt (nentsel "\n請選擇需要替換的文字目標:"))
(if (= bltxt nil)(setq q nil)
(progn
(setq entdata (entget (car bltxt)) btxt (cdr (assoc 1 entdata)) ostr btxt)
(setq elist (entget (car bltxt)))
(setq etype (cdr (assoc 0 elist)))
;;(setq oltxt (car (assoc 1 elist)))
(setq oltxt (cdr (assoc 1 elist)))
(if (= etype "ATTRIB")
(progn
(setq pt (cadr bltxt))
(command ".attedit" "" "" "" "" pt "" "V" "R" oldval "n")
(progn
(setq btxt oldval)
(entmod (subst (cons 1 btxt)(assoc 1 entdata) entdata))
(if (setq bltxt (car (reverse (cadddr bltxt)))) (entupd bltxt))
(princ "\n原文字為:")(princ oltxt)(princ ". 已被替換為: ")(princ oldval)(princ " .")
(princ)
发表于 2004-9-17 20:59:25 | 显示全部楼层
此程序可这么小改一下! 第二点要求没有意义,多按次回车不就行了?  原程序还方便了许多!
发表于 2004-9-17 21:00:52 | 显示全部楼层
代码
  1.   [FONT=courier new]
  2. (defun c:thh (/ a b ent ent2 elist etype oldval bltxt entdata btxt ostr pt oltxt )
  3. (princ "\n ******* 文字替换程序 ******* Writen by 正航")
  4. (princ "\n 请选择复制源文字目标:")
  5. (setq ent (nentsel))
  6. (if (= ent nil)(setq oldval (getstring "\n 请输入文字:"))
  7. (progn
  8. (setq bb (car ent))
  9. (redraw bb 3)
  10. (setq
  11. ent2 ent
  12. elist (entget bb)
  13. etype (cdr (assoc 0 elist))
  14. )
  15. (setq oldval (cdr (assoc 1 elist)))
  16. (princ "\n ")
  17. (princ "\n复制文字内容为: ") (princ oldval)
  18. )
  19. )
  20. (setq q 9)
  21. (while q
  22. (princ "\n ")
  23. (setq bltxt (nentsel "\n请选择需要替换的文字目标:"))
  24. (if (= bltxt nil)(setq q nil)
  25. (progn
  26. (setq entdata (entget (car bltxt)) btxt (cdr (assoc 1 entdata)) ostr btxt)
  27. (setq elist (entget (car bltxt)))
  28. (setq etype (cdr (assoc 0 elist)))
  29. ;; (setq oltxt (car (assoc 1 elist)))
  30. (setq oltxt (cdr (assoc 1 elist)))
  31. (if (= etype "ATTRIB")
  32. (progn
  33. (setq pt (cadr bltxt))
  34. (command ".attedit" "" "" "" "" pt "" "V" "R" oldval "n")
  35. )
  36. (progn
  37. (setq btxt oldval)
  38. (entmod (subst (cons 1 btxt)(assoc 1 entdata) entdata))
  39. (if (setq bltxt (car (reverse (cadddr bltxt)))) (entupd bltxt))
  40. ))))
  41. (princ "\n原文字为:")(princ oltxt)(princ ". 已被替换为: ")(princ oldval)(princ " .")
  42. )
  43. (redraw bb 4)
  44. (princ)
  45. )
  46.   [/FONT]
 楼主| 发表于 2004-9-18 01:02:54 | 显示全部楼层
謝謝大大,但小弟的第二點要求是小弟急需的,卻不知如何修改,求大大幫幫忙!
发表于 2004-9-18 08:45:39 | 显示全部楼层
去掉
(setq q 9)
(while q
(princ "\n ")
还有  (redraw bb 4)   上面的  " )"  右括号!
 楼主| 发表于 2004-9-18 22:22:24 | 显示全部楼层
請問大大,照大大的指示修改後,為何執行過一次後,再選取其他文字就不會再顯亮了,這是什麼原因?
发表于 2004-9-18 23:52:32 | 显示全部楼层
不明白你的意思! 修改过的代码,执行过一次后!程序就退出了! 要想再去改文字, 就再启动程序一遍!  第一次能显亮, 第二次启动程序还是会显亮啊!  不知你怎么改的!
GMT+8, 2026-11-6 15:22 , Processed in 0.475991 second(s), 44 queries , Gzip On.
