查看: 1888|回复: 3
[讨论]:如何检测键盘状态?
发表于 2004-9-19 12:17:52 | 显示全部楼层 |阅读模式
如何检测键盘状态? 如caps Lock, Num Lock
我找到一个vb程序,但不知能否在lisp中调用?
Public Declare Function GetKeyState Lib "user32" (ByVal nVirtKey As Long) As
Long
Public Declare Function GetKeyboardState Lib "user32" (kbArray As
KeyboardBytes) As Long
Public Declare Function SetKeyboardState Lib "user32" (kbArray As
Public Type KeyboardBytes
kbByte(0 To 255) As Byte
End Type
Public kbArray As KeyboardBytes
Public CapsLock As Boolean
Public kbOld As KeyboardBytes
Global Const VK_CAPSLOCK = &H14
Global Const VK_NUMLOCK = &H90
Global Const VK_SCROLL = &H91
Public Sub TurnOn(vkKey As Long)
'save the original keyboard state
GetKeyboardState kbOld
'Get the keyboard state
GetKeyboardState kbArray
'Change a key
kbArray.kbByte(vkKey) = 1
'Set the keyboard state
SetKeyboardState kbArray
End Sub
Public Sub TurnOff(vkKey As Long)
'change a key
kbArray.kbByte(vkKey) = 0
'set the keyboard state
End Sub
Public Sub Reset()
'restore the old keyboard state
SetKeyboardState kbOld
End Sub
Public Function IsCapsLock() As Boolean
If GetKeyState(VK_CAPSLOCK) And 1 Then
IsCapsLock = True
Else
IsCapsLock = False
End If
End Function
Public Function IsNumLock() As Boolean
If GetKeyState(VK_NUMLOCK) And 1 Then
IsNumLock = True
Else
IsNumLock = False
End If
End Function
Public Function IsScrollLock() As Boolean
If GetKeyState(VK_SCROLL) And 1 Then
IsScrollLock = True
Else
IsScrollLock = False
End If
End Function
发表于 2004-9-19 13:34:32 | 显示全部楼层
是要调用Api的,只能做成宏,再用Lisp和VBA传递参数调用
发表于 2004-9-28 20:27:22 | 显示全部楼层
http://www.mcneel.com/download.htm
doslib-adds DOS and Windows commands to AutoLISP.
命令dos_numlock
命令dos_scrolllock
 楼主| 发表于 2004-9-28 23:11:08 | 显示全部楼层
DosLib 只能改变状态,并不能检测。
GMT+8, 2026-11-5 10:11 , Processed in 0.395125 second(s), 38 queries , Gzip On.
