查看: 859|回复: 1
[LISP程序]:批处理多图形文件创建新图层
发表于 2004-9-20 07:01:14 | 显示全部楼层 |阅读模式
批处理多图形文件创建新图层
[php]
(defun c:test ()
  ;(vl-load-com)
  (setq layname (getstring "\n Input the Name of Layer: "))
  (setq col (getstring "\nColor Number: "))
  (setq lty (getstring "\nLinetype<Continuous>: "))
  (if (= lty "")(setq lty "Continuous"))
  (vlax-for i (vla-get-Documents (vlax-get-acad-object))
    (if (vl-catch-all-error-p
          (setq
            olayer
            (vl-catch-all-apply 'vla-add
              (list (vla-get-layers i) layname)
      nil
      (cond (olayer (vla-put-color olayer col)(vla-put-linetype olayer lty)))
[/php]
发表于 2004-9-20 13:52:27 | 显示全部楼层
樓主應用在哪方面?
GMT+8, 2026-11-5 10:12 , Processed in 0.284652 second(s), 34 queries , Gzip On.
