查看: 2269|回复: 10
[LISP程序]:修改别人的插入当前时间段!
发表于 2004-9-22 13:24:09 | 显示全部楼层 |阅读模式
(defun c:rq (/ tmp cy cm cd txt txt1 pt1)
  (setq tmp (rtos (getvar "cdate") 2 16))
  (setq cy (rtos (atof (substr tmp 1 4)) 2 0)
cm (rtos (atof (substr tmp 5 2)) 2 0)
cd (rtos (atof (substr tmp 7 2)) 2 0)
  (cond ((= cm "1")(setq cm "Jan"))
       ((= cm "2")(setq cm "Feb"))
       ((= cm "3")(setq cm "Mar"))
       ((= cm "4")(setq cm "Apr"))
       ((= cm "5")(setq cm "May"))
       ((= cm "6")(setq cm "Jun"))
       ((= cm "7")(setq cm "Jul"))
       ((= cm "8")(setq cm "Aug"))
       ((= cm "9")(setq cm "Sep"))
       ((= cm "10")(setq cm "Oct"))
       ((= cm "11")(setq cm "Nov"))
       ((= cm "12")(setq cm "Dec"))
  );cond
  (setq txt (strcat "现在是:" cd "," cm "," cy " ")
txt1 (strcat cd "," cm "," cy " ")
  (COMMAND "style" "宋体" "宋体" "300" "1" "0" "" "")
  (alert txt)
  (setq pt1(getpoint"\n\t放置点 : "))
  (command "text" "j" "mc" pt1 "0" txt1)
  (princ)
哪位大侠帮忙修改一下,使之变为点选文字使之内容变为当前时间!
恨自己不懂LISP的编写,只会照猫画虎.
发表于 2004-11-22 00:44:02 | 显示全部楼层
重新生成就可以了!
[php]
(defun c:rq (/ tmp cy cm cd hh mm ss ms txt pt1)
  (setq tmp (rtos (getvar "cdate") 2 16));系统当前时间
  (setq
        cy (rtos (atof (substr tmp 1 4)) 2 0);年
        cm (rtos (atof (substr tmp 5 2)) 2 0);月
        cd (rtos (atof (substr tmp 7 2)) 2 0);日
        hh (rtos (atof (substr tmp 10 2)) 2 0);时
        mm (rtos (atof (substr tmp 12 2)) 2 0);分
        ss (rtos (atof (substr tmp 14 2)) 2 0);秒
        ms(rtos (atof (substr tmp 16 2)) 2 0);毫秒
  (setq txt (strcat "现在是:" cy "年"cm "月" cd "日" hh"时" mm "分" ss "秒" ms "毫秒"))
  (setq pt1 (getpoint "\n\t放置点 : "))
  (alert txt)
  (command "text" "j" "mc" pt1 "0" txt)
  (princ)
[/php]
发表于 2004-11-24 21:42:09 | 显示全部楼层
这下时间就特别精确了。不过还是弹出对话框比较酷哦。
 楼主| 发表于 2004-11-25 10:08:50 | 显示全部楼层
我这是为了方便在标题栏写时间的,一般我们只写年月日,不用到时分.
我只会照猫画虎,不会自己编,所以没法满足4楼主的要求,等好心的高手帮忙改吧!
发表于 2004-11-25 20:09:49 | 显示全部楼层
最初由 xyp1964 发布
[B]重新生成就可以了!
[php]
        cm (rtos (atof (substr tmp 5 2))... [/php][/B]
[php]
(defun c:cd ( / da lst)
  (setq da (rtos(getvar "cdate")2 8)
        lst(mapcar '(lambda(x)(substr da (car x) (cadr x))) '((1 4) (5 2) (7 2) (10 2)(12 2)(14 2)(16 2))))
  (vl-cmdf ".text" "j" "mc" pt1 "0"
  (apply 'strcat (mapcar '(lambda(x y)(strcat x y)) lst '("年" "月" "日" "时" "分" "秒" "毫秒")))
    (princ)
[/php]
发表于 2004-11-25 21:14:26 | 显示全部楼层
最初由 狂刀 发布
[B][QUOTE]最初由 xyp1964 发布
[B]重新生成就可以了!
[php]
  (setq        cy (rtos (atof (substr tmp 1 4)) 2... [/B]
(100-2)×(100+2)=9604
是不是说应该写成:
98×102=9604
发表于 2004-11-26 01:11:32 | 显示全部楼层
什么意思??不明白
发表于 2004-11-26 08:29:20 | 显示全部楼层
高手们,能整理一下么?不太明白呀?
谢谢!
发表于 2004-12-26 22:19:58 | 显示全部楼层
我也很想学学LISP,一直不得入门,高手们能指条路吗?或者发点基础的教学资料上来?
已领礼包: 3661个
发表于 2004-12-27 10:15:09 | 显示全部楼层
高手们,能整理一下么?不太明白呀?
谢谢!
CAD中系统时间是用一串数字表示的,找出其规律就能提出当前时间来
to yb0642,注意看看吧,论坛里其实很多基础教程的
如下
http://www.xdcad.net/forum/showthread.php?s=&threadid=316324
发表于 2006-2-23 10:19:32 | 显示全部楼层
学习一下
GMT+8, 2026-11-7 00:48 , Processed in 0.650419 second(s), 53 queries , Gzip On.
