查看: 803|回复: 1
[分享]:[源码]region转pl 和 线转pl的程序
发表于 2004-9-23 19:54:56 | 显示全部楼层 |阅读模式
  1. ;;;Written by WKAI @ XDCAD.NET________________
  2. ;;;___________________________________________
  3. (DEFUN c:region_to_pl (/ region_ent)
  4. (PRINC "\n选择需要转换为PL的REGION:")
  5. (SETVAR "cmdecho" 0)
  6. (SETQ region_ent (SSGET '((0 . "REGION"))))
  7. (IF region_ent
  8.   (PROGN
  9.    (COMMAND "._explode" region_ent)
  10.    (COMMAND)
  11.    (l_to_pl (SSGET "p"))
  12.   )
  13. )
  14. )
  15. (DEFUN l_to_pl (ssa / ss1 lines ent n)
  16. (COMMAND "._undo" "be")
  17. (SETQ ss1 (SSADD))
  18. (REPEAT (SETQ n (SSLENGTH ssa))
  19.   (SETQ ent (SSNAME ssa (SETQ n (1- n))))
  20.   (IF (AND (ENTGET ent)
  21.            (MEMBER (CDR (ASSOC 0 (ENTGET ent)))
  22.                    '("LINE" "ARC" "POLYLINE" "LWPOLYLINE")
  23.            )
  24.       )
  25.    (SETQ ss1 (SSADD ent ss1))
  26.   )
  27. )
  28. (SETQ lines ss1)
  29. (l_to_pl:main)
  30. (COMMAND "._undo" "e")
  31. )
  32. (DEFUN l_to_pl:main (/ ent ss1 n)
  33. (SETQ ent (SSNAME lines 0))
  34. (IF (MEMBER (CDR (ASSOC 0 (ENTGET ent)))
  35.              '("POLYLINE" "LWPOLYLINE")
  36.      )
  37.   (IF (/= 1 (LOGAND (CDR (ASSOC 70 (ENTGET ent))) 1))
  38.    (COMMAND "._pedit" ent "j" lines "" "")
  39.   )
  40.   (COMMAND "._pedit" ent "y" "j" lines "" "")
  41. )
  42. (SETQ lines (SSDEL ent lines))
  43. (SETQ ss1 (SSADD))
  44. (REPEAT (SETQ n (SSLENGTH lines))
  45.   (SETQ ent (SSNAME lines (SETQ n (1- n))))
  46.   (IF (ENTGET ent)
  47.    (SETQ ss1 (SSADD ent ss1))
  48.   )
  49. )
  50. (SETQ lines ss1)
  51. (WHILE (> (SSLENGTH lines) 0) (l_to_pl:main))
  52. )
发表于 2006-6-26 11:21:03 | 显示全部楼层
请说出程序的优点和使用方法。
GMT+8, 2026-11-3 11:31 , Processed in 0.440527 second(s), 34 queries , Gzip On.
