查看: 845|回复: 1
[求助] [求助]:这样之后怎样读取sheet1中的a1
发表于 2004-10-3 17:02:01 | 显示全部楼层 |阅读模式
(vl-load-com)
(setq excelapp (vlax-get-object "excel.application")
          activeworkbook (vlax-get-property excelapp "activeworkbook")
          sheets (vlax-get-property activeworkbook "worksheets")
          sheet1 (vlax-get-property sheets "item" "sheet1")
清高手多多指教.
发表于 2004-10-3 22:55:09 | 显示全部楼层
(vlax-variant-value (vlax-get-property (vlax-get-property sheet1 'range "A1") 'value))
GMT+8, 2026-10-16 05:09 , Processed in 0.396154 second(s), 34 queries , Gzip On.
