查看: 995|回复: 6
[原创]:OFFSET在LISP中如何实现?
发表于 2004-10-18 22:40:14 | 显示全部楼层 |阅读模式
怎么确定偏移的方向呢?如果是圆或是圆弧可以根据圆心定位,如果是直线怎么办?
发表于 2004-10-18 23:48:26 | 显示全部楼层
可以从直线的角度入手
发表于 2004-10-19 07:17:03 | 显示全部楼层
(From on-line help, but sometimes it's not right)
The distance to offset the object. The offset can be a positive or negative number, but it cannot equal zero. If the offset is negative, this is interpreted as being an offset to make a "smaller" curve (that is, for an arc it would offset to a radius that is "Distance less" than the starting curve's radius). If "smaller" has no meaning, then it would offset in the direction of smaller X, Y, and Z WCS coordinates.
 楼主| 发表于 2004-10-22 20:48:20 | 显示全部楼层
2楼能否解释一下?
发表于 2004-10-23 10:50:48 | 显示全部楼层
你可以点击直线,找到两端点坐标,然后求出直线方向
发表于 2004-11-7 23:39:12 | 显示全部楼层
在程序中使用offset时你可以先用鼠标指定一个方向,然后就程序自动复制直线了。这样简单而实用,否则太多的判断反倒容易出错。
给个例子:
(defun c:pjhx()
         (command "layer" "m" "jhx" "c" "yellow" "jhx" command)
         (command "layer" "s" "jhx" command)
         (setq xnum (getint "\n请输入线数: "))
         (if (= xnum nil)(setq xnum 0))
         (setq dnum (getreal "\n请输入线间距离: "))
         (if (= dnum nil)(setq dnum 0))
         (setq s (ssget))
         (setq s1 (ssname s 0))
         (command "change" s "" "p" "la" "jhx" "")
         (setq p (getpoint "\n请确定偏移方向: "))
         (setq cont 0)
         (while (< cont xnum)
                (setq data (entget s1))
                (setq pstart (assoc 10 data))
                (setq pstarty (nth 1 pstart))
                (setq pstartx (nth 2 pstart))
                (setq p1 (list pstarty pstartx))
                (if(= cont 0) (setq fx (angle p1 p)))
                (setq p (polar p1 fx dnum))
                (command "offset" dnum s1 p "")
                (setq s1 (entlast))
                (setq cont (+ cont 1))
运行这个例子时,必须先有一根直线存在。
程序运行后会提示你选中这根直线,右键确定,然后左键在你需要便移的方向点击一下即可。
发表于 2004-11-10 13:53:27 | 显示全部楼层
可以得到起始和终点坐标,再用新点表代替
GMT+8, 2026-11-5 10:59 , Processed in 0.381644 second(s), 44 queries , Gzip On.
