查看: 1827|回复: 2
[LISP程序]:序号球程序
发表于 2003-1-22 09:58:30 | 显示全部楼层 |阅读模式
  1. ;;By LUCAS(龙龙仔)
  2. ;;注意:序号球是属性图块,用ddatte指令修改
  3. ;;引线箭头用'_dimstyle修改
  4. ;;只要增加一些属性,就可做料表了!!!!
  5. (defun C:OS (/ HOLDOSMODE HOLDDIA HOLDREQ INS A        AZ B2 B1 AL PT PT1 PT2 ANG)
  6.   (defun OPTION        ()
  7.     (initget 6)
  8.     (setq A (getreal
  9.               (strcat "\n记号直径<" (rtos (getvar "userr4")) ">: ")
  10.             )
  11.     )
  12.     (if        (/= NIL A)
  13.       (setvar "userr4" A)
  14.     )
  15.     (initget 6)
  16.     (setq NOS (getint (strcat "\n起始数字<"
  17.                               (rtos (1+ (getvar "useri4")))
  18.                               ">: "
  19.                       )
  20.               )
  21.     )
  22.     (if        (= NIL NOS)
  23.       (setq NOS (1+ (getvar "useri4")))
  24.     )
  25.     (setvar "useri4" (- NOS 1))
  26.   )
  27.   (command "_.undo" "_group")
  28.   (setq HOLDOSMODE (getvar "osmode"))
  29.   (setq HOLDDIA (getvar "ATTDIA"))
  30.   (setq HOLDREQ (getvar "ATTREQ"))
  31.   (setvar "osmode" 0)
  32.   (if (= (getvar "userr4") 0)
  33.     (setvar "userr4" (* 4 (getvar "DIMSCALE")))
  34.   )
  35.   (while (= NIL INS)
  36.     (initget "P")
  37.     (setq INS (getpoint        (strcat        "\n指定引线起点 /[记号直径<"
  38.                                 (rtos (getvar "userr4"))
  39.                                 ">][数字<"
  40.                                 (rtos (1+ (getvar "useri4")))
  41.                                 ">](选项<P>): "
  42.                         )
  43.               )
  44.     )
  45.     (setq PT2 NIL)
  46.     (cond
  47.       ((= INS NIL)
  48.        (setq INS 1)
  49.       )
  50.       ((= INS "P")
  51.        (OPTION)
  52.       )
  53.       (t
  54.        (setq PT1 INS)
  55.        (command "_.LEADER" PT1)
  56.        (while (= 1 (getvar "CMDACTIVE"))
  57.          (setq PT PT1)
  58.          (prompt "\n指定下一点: ")
  59.          (command PAUSE)
  60.          (if (/= PT2 NIL)
  61.            (setq PT1 PT2)
  62.          )
  63.          (if (equal (getvar "lastpoint") PT2)
  64.            (progn
  65.              (if (equal PT PT1)
  66.                (setq ANG (angle PT (setq PT1 (getvar "lastpoint"))))
  67.                (setq ANG (angle PT PT1))
  68.              )
  69.              (setq INS (polar PT1 ANG (/ (getvar "userr4") 2.0)))
  70.              (setq NOS (1+ (getvar "useri4")))
  71.              (setvar "useri4" NOS)
  72.              (setvar "ATTDIA" 0)
  73.              (setvar "ATTREQ" 1)
  74.              (if (not (tblsearch "BLOCK" "NOS1"))
  75.                (MBA)
  76.              )
  77.              (command "" "B" "NOS1" INS (getvar "userr4") "" "" NOS)
  78.              (setvar "ATTDIA" HOLDDIA)
  79.              (setvar "ATTREQ" HOLDREQ)
  80.              (setq AZ (ssget "l"))
  81.              (setq B2 (ssname AZ 0))
  82.              (while (/= "数字" (cdr (assoc 2 (entget B2))))
  83.                (setq B2 (entnext B2))
  84.              )
  85.              (setq B2 (entget B2))
  86.              (setq B1 (cdr (assoc 1 B2)))
  87.              (setq AL (strlen B1))
  88.              (cond
  89.                ((= AL 3)
  90.                 (setq B2 (subst (cons 41 0.64) (assoc 41 B2) B2))
  91.                 (entmod B2)
  92.                 (entupd (ssname AZ 0))
  93.                )
  94.                ((= AL 4)
  95.                 (setq B2 (subst (cons 41 0.475) (assoc 41 B2) B2))
  96.                 (entmod B2)
  97.                 (entupd (ssname AZ 0))
  98.                )
  99.                ((= AL 5)
  100.                 (setq B2 (subst (cons 41 0.38) (assoc 41 B2) B2))
  101.                 (entmod B2)
  102.                 (entupd (ssname AZ 0))
  103.                )
  104.              )
  105.            )
  106.            (setq PT2 (getvar "lastpoint"))
  107.          )
  108.        )
  109.        (setq INS NIL)
  110.       )
  111.     )
  112.   )
  113.   (setvar "osmode" HOLDOSMODE)
  114.   (command "_.undo" "_end")
  115.   (princ)
  116. )
  117. ;;;生成带属性图块。
  118. (defun MBA ()
  119.   (entmake (append '((0 . "LAYER")
  120.                      (100 . "AcDbSymbolTableRecord")
  121.                      (100 . "AcDbLayerTableRecord")
  122.                      (70 . 0)
  123.                      (2 . "TEXT")
  124.                      (62 . 6)
  125.                      (6 . "Continuous")
  126.                     )
  127.            )
  128.   )
  129.   (entmake '((0 . "STYLE")
  130.              (100 . "AcDbSymbolTableRecord")
  131.              (100 . "AcDbTextStyleTableRecord")
  132.              (2 . "OS")
  133.              (70 . 0)
  134.              (40 . 0.0)
  135.              (41 . 1.0)
  136.              (50 . 0.0)
  137.              (71 . 0)
  138.              (42 . 26.7011)
  139.              (3 . "SIMPLEX.shx") ;;修改字体
  140.              (4 . "")
  141.             )
  142.   )
  143.   (entmake
  144.     '((0 . "block") (2 . "NOS1") (70 . 2) (10 0.0 0.0 0.0))
  145.   )
  146.   (entmake '((0 . "CIRCLE")
  147.              (100 . "AcDbEntity")
  148.              (67 . 0)
  149.              (410 . "Model")
  150.              (8 . "0")
  151.              (62 . 256)
  152.              (100 . "AcDbCircle")
  153.              (10 0.0 0.0 0.0)
  154.              (40 . 0.5)
  155.              (210 0.0 0.0 1.0)
  156.             )
  157.   )
  158.   (entmake '((0 . "ATTDEF")
  159.              (100 . "AcDbEntity")
  160.              (67 . 0)
  161.              (410 . "Model")
  162.              (8 . "text")
  163.              (100 . "AcDbText")
  164.              (10 -0.519828 -0.225 0.0)
  165.              (40 . 0.45)
  166.              (1 . "1")
  167.              (50 . 0.0)
  168.              (41 . 1.0)
  169.              (51 . 0.0)
  170.              (62 . 256)
  171.              (7 . "OS")
  172.              (71 . 0)
  173.              (72 . 1)
  174.              (11 0.0 0.0 0.0)
  175.              (210 0.0 0.0 1.0)
  176.              (100 . "AcDbAttributeDefinition")
  177.              (3 . "数字")
  178.              (2 . "数字")
  179.              (70 . 0)
  180.              (73 . 0)
  181.              (74 . 2)
  182.             )
  183.   )
  184.   (entmake '((0 . "ENDBLK")))
  185.   (princ)
  186. )
发表于 2003-2-7 03:25:51 | 显示全部楼层
班门弄斧了, 请指教.
(defun itemnum ( / ps pe s)
  (if inum nil (setq inum 1))
  (princ "\nType in Item Number <")
  (princ inum)
  (setq inum0 (getint ">:"))
  (if inum0 (setq inum inum0))
  (mlayer "dim" 4 "continous")
  (setq s (getvar "dimscale"))
  (setq ps (getpoint "\nPick Start Point"))
  (setvar "osmode" 37)
  (setq pe (getpoint "\nPick End Point"))
  (setvar "osmode" 0)
  (command "leader" ps (polar pe (angle pe ps)(* s 0.32)) "" "" "n")
  (vl-cmdf "circle"  pe (* s 0.32))
  (vl-cmdf "text" "j" "m" pe (* s 1.5 0.18) 0 (itoa inum) "")
  (setq inum (1+ inum))
);defun_itemnum
发表于 2004-4-29 15:09:10 | 显示全部楼层
转贴网址就好了!
GMT+8, 2026-11-3 10:21 , Processed in 0.485173 second(s), 36 queries , Gzip On.
