查看: 937|回复: 3
[求助] [求助]:一个程序的问题,较急!!
发表于 2004-11-26 09:21:48 | 显示全部楼层 |阅读模式
哪位能帮一下,这个程序为何文字那儿有错??
(defun jx ()
  (setq l 30 b 20)
  (setq ax1 100 ay1 100)
  (setq ax3 (+ ax1 l) ay3 (+ ay1 b))
  (setq a1 (list ax1 ay1)
        a2 (list ax3 ay1)
        a3 (list ax3 ay3)
        a4 (list ax1 ay3)
  (command "line" a1 a2 a3 a4 "c")
  (command "dtext"   (110,85)   5  0  "qinyong" " ")
初学编程,望各位老大帮助。
发表于 2004-11-26 09:41:06 | 显示全部楼层
(defun jx (/ A1 A2 A3 A4 AX1 AX3 AY1 AY3 B L)
(setq l 30 b 20)
a2 (list ax3 ay1)
a3 (list ax3 ay3)
a4 (list ax1 ay3)
(command "text" '(110 85) 5 0 "qinyong")
 楼主| 发表于 2004-11-26 14:58:33 | 显示全部楼层
多谢指点。
发表于 2004-11-26 21:29:00 | 显示全部楼层
也可这样:
(command "text" “110,85" 5 0 "qinyong")
GMT+8, 2026-11-5 12:32 , Processed in 0.392487 second(s), 38 queries , Gzip On.
