查看: 972|回复: 2
[编程申请]:多义线字段长度按DX的部分程序写了一个,可惜有错!请DX看看。
发表于 2004-11-30 16:47:41 | 显示全部楼层 |阅读模式
代码如下:
(defun c:pljl (/ ll)
  (setvar "cmdecho" 0)
  (setq ffn (getfiled "选取文件" "" "doc" 1))
  (setq ff (open ffn "w"))
  (close ff)
  (setq a (car (entsel "\nSelect Polyline:")))
  (setq num (cdr (assoc 90 (entget a))) n 1)
  (while (< n num)
    (setq l (- (vlax-curve-getDistAtParam a n)
               (vlax-curve-getDistAtParam a (1- n))))
    (setq ff (open ffn "a"))
    (princ l ff)
    (princ "     " ff)
    (princ "\n" ff)
    (close ff)
发表于 2004-12-1 11:35:08 | 显示全部楼层
  1. 注意:n值
  2. (defun C:PLJL (/ LL)
  3.   (setvar "cmdecho" 0)
  4.   (setq FFN (getfiled "選取文件" "" "txt" 1))
  5.   (setq FF (open FFN "w"))
  6.   (close FF)
  7.   (setq A (car (entsel "\nSelect Polyline:")))
  8.   (setq        NUM (cdr (assoc 90 (entget A)))
  9.         N   1
  10.   )
  11.   (setq FF (open FFN "a"))
  12.   (while (< N NUM)
  13.     (setq L (- (vlax-curve-getdistatparam A N)
  14.                (vlax-curve-getdistatparam A (1- N))
  15.             )
  16.           N (1+ N)
  17.     )
  18.     (princ L FF)
  19.     (princ " " FF)
  20.   )
  21.   (princ "\n" FF)
  22.   (close FF)
  23. )
 楼主| 发表于 2004-12-1 19:11:28 | 显示全部楼层
多谢斑竹帮助,可以用了。不过我的水平实在很差,怎么样才能实现一次选择多条PL线并提取它们的子段长度呢?现在只是一条。
GMT+8, 2026-11-23 17:15 , Processed in 0.382679 second(s), 14 queries , Gzip On, File On.
