查看: 909|回复: 4
[求助] [求助]:如何过滤文字?
发表于 2004-12-5 13:24:06 | 显示全部楼层 |阅读模式
在进行autolisp进行编写程序时,我想提取文字中的数字如“K3+510”,我想提取其中的3510,而自动过滤掉"K"和"+",如何实现这个目标呢?能不能实现这个目标呢?如果能,望兄台指点一二,举一两个例子,让小弟也学学。
发表于 2004-12-5 22:51:39 | 显示全部楼层
; By Bill Kramer----------------------------------------------------- Listing 4.4
; Useage: (String_To_Numbers "K3+150")
(defun String_To_Numbers (
                          inStr  ;;Input string
                          Res    ;;Result list
                          Buf    ;;String buffer
                          Inx      ;;Character location
                          CH     ;;Character
  (setq Inx 1 ;start at the beginning of the string
        Buf "" ;init buffer to empty
  ; Loop until the end of the string.
  ; (I indicates where we are in the string)
  (while (<= Inx (strlen inStr))
    ; Get the character at position Inx, increment position indicator
    (setq CH (substr inStr Inx 1)
          Inx (1+ Inx)
    (cond
      ; Test to see if character is a digit.
      ((wcmatch CH "[0-9.]")
        (if (= CH ".") ;is it decimal?
          (if (not (wcmatch Buf "*`.*")) ;not already in there
            (setq Buf (strcat Buf CH))
            (Flush_Buf))
          (setq Buf (strcat Buf CH)))
      ((= Buf "") ;is the buffer empty?
               ;Is CH minus
        (if (= CH "-")
          (setq Buf CH) ;Yes, save in Buf
      ('T ;else buffer is not empty
        (Flush_Buf)
        (if (= CH "-")
          (setq Buf CH))
    ); End of COND
  ); End of WHILE
  (if (and (/= Buf "")
           (not (wcmatch Buf "[+-.]"))
    (Flush_Buf))
  (reverse Res)
; ------------------------------------------------------ Listing 4.5
(defun Flush_Buf ()
  (if (not (wcmatch Buf "[+-.]")) ;is it not just +-.?
    (progn
      ;Clean it up first
      (if (= (substr Buf 1 1) ".")
        (setq Buf (strcat "0" Buf))) ;;add zero to front if .#
      (if (= (substr Buf (strlen Buf)) ".")
        (setq Buf (substr Buf 1 (1- (strlen Buf))))) ;;remove decimal if #.
      ;Add to RES list
      (setq RES (cons Buf RES))))
  (setq Buf "") ;;reset Buf
发表于 2004-12-6 11:05:31 | 显示全部楼层
楼上仁兄的程序真是不错,受教了,不过“1楼楼主”是学公路的,所以程序最后应把数字连接起来形成一个完整的数值。不过程序整体通用性好。
发表于 2004-12-6 12:40:49 | 显示全部楼层
  1. (vl-list->string
  2.   (vl-remove 'NIL
  3.              (mapcar '(lambda (X)
  4.                         (if (member
  5.                               X
  6.                               '(48 49 50 51 52 53 54 55 56 57 46)
  7.                             )
  8.                           X
  9.                         )
  10.                       )
  11.                      (vl-string->list "K3+510")
  12.              )
  13.   )
  14. )
发表于 2004-12-6 20:29:33 | 显示全部楼层
这个 (vl-remove 'NIL 用的好
GMT+8, 2026-11-5 14:43 , Processed in 0.544382 second(s), 40 queries , Gzip On.
