查看: 1399|回复: 0
[求助]:请教高手setUserInputControls
发表于 2004-12-28 13:22:42 | 显示全部楼层 |阅读模式
帮助里面是这样写的:
Use the following function to change the default user input controls:
void setUserInputControls(AcEdJig::UserInputControls uic);
The user input controls put limitations on the drag sequence or the type of acceptable return value (for example, by not allowing negative responses, by not allowing a zero response, or by restricting the input value to a 2D coordinate). They also specify how various user actions affect the drag sequence. For example, kAcceptMouseUpAsPoint specifies that releasing the mouse button indicates the input value
主要想问:For example, kAcceptMouseUpAsPoint specifies that releasing the mouse button indicates the input value
这个是通过什么实现的?通过系统变量吗?其他如Lisp或VBA能否实现?
GMT+8, 2026-11-22 07:56 , Processed in 0.269616 second(s), 10 queries , Gzip On, File On.
