查看: 930|回复: 0
[求助]:关于拖动多义线时worldDraw函数重载的问题
发表于 2005-2-28 15:33:44 | 显示全部楼层 |阅读模式
我在用AcedJig实现拖动一个2dpolyline的实体时,重载了worldDraw函数,但是在CAD中执行时,总是提示
(Two vertices were added to a 2D pline (0) which had no vertices.)
请教这到底是什么问题,3x
virtual Adesk::Boolean worldDraw(AcGiWorldDraw* mode)
        Adesk::Boolean es = Adesk::kTrue;
        mode->subEntityTraits().setColor(7);
        AcDbEntity *pEntity = NULL;
        AcDbEntity *pDraw = NULL;
        es = acdbOpenAcDbEntity(pEntity, Id, AcDb::kForRead);
        if(es != Acad::eOk)
                return es;
        pDraw = AcDbEntity::cast(pEntity->clone());
        //pDraw = (AcDbEntity*)(pEntity->clone());
        pEntity->close();
        AcGeMatrix3d max;
        max = AcGeMatrix3d(del);
        if(pDraw != NULL)
                es = pDraw->transformBy(max);
                es = mode->geometry().draw(pDraw);
        pDraw->close();
        return es;
GMT+8, 2026-11-22 09:10 , Processed in 0.328623 second(s), 10 queries , Gzip On, File On.
