查看: 1344|回复: 0
[LISP程序]:坐标点展绘
发表于 2003-2-17 18:28:26 | 显示全部楼层 |阅读模式
这是开始学Lisp学习时写的,用来展绘坐标点并记点号或者高程等字符注记,在Acad 2000上运行。运行速度不快(约10点/s)
加载程序后,输入“zd”命令就可运行。
数据格式:
第一行为总点数
第二行是:1点 点名,1点 编码,1点 Y(东)坐标,1点 X(北)坐标,1点 高程
第n行是:n-1点 点名,n-1点 编码,n-1点 Y(东)坐标,n-1点 X(北)坐标,n-1点 高程
例:4
1,f1,497728.882,86448.407,14.267
2,dx,497726.893,86454.135,14.575
3,gcd,497720.004,86453.003,13.654
4,dl,497728.950,86454.895,14.513
数据文件扩展名为dat(*.dat)
;;;本程序用于坐标点展。数据格式沿用南方仪器公司cass的格式
;;;点名,编码,Y(东)坐标,X(北)坐标,(Z)高程
;;;如果要展代码、高程请将(command "zoom" "e")中的"e"改成"e2"或者是""h""
  1. (defun C:zd (/ fi b n e e2 y x h n2 p1 p2)
  2. ;;;  (print
  3. ;;;    "\n 您好!欢迎您!这里是展绘点号程序,确认后,选择数据文件\n"
  4. ;;;    )
  5.   (setq        fi (open
  6.              (getfiled "请选择数据文件" "" "dat" 8)
  7.              "r"
  8.              )
  9.         )
  10.   (setq        b
  11.          (read
  12.            (read-line fi)
  13.            )
  14.         )
  15.   (setq n 1)
  16.   (command "layer" "s" "0" "")
  17. ;;;  (setvar "AutoSnap" 0)
  18.   (while (<= n b)
  19.     (setq d
  20.            (read-line fi)
  21.           )
  22. ;;;读取点号( 数据格式是:点号,代码,Y坐标,X坐标,高程)
  23.     (setq start-pos (vl-string-search "," d 0))
  24.     (setq e
  25.            (substr d 1 start-pos)
  26.           )
  27. ;;;读码
  28.     (setq n2 (1+ start-pos))
  29.     (setq start-pos (vl-string-search "," d n2))
  30.     (setq e2
  31.            (substr d (1+ n2) (- start-pos n2))
  32.           )
  33. ;;;读取横坐标
  34.     (setq n2 (1+ start-pos))
  35.     (setq start-pos (vl-string-search "," d n2))
  36.     (setq y
  37.            (substr d (1+ n2) (- start-pos n2))
  38.           )
  39. ;;;读取纵坐标
  40.     (setq n2 (1+ start-pos))
  41.     (setq start-pos (vl-string-search "," d n2))
  42.     (setq x
  43.            (substr d (1+ n2) (- start-pos n2))
  44.           )
  45. ;;;读取高程
  46.     (setq n2 (1+ start-pos))
  47.     (setq start-pos (vl-string-search "," d n2))
  48.     (setq h
  49.            (substr d (1+ n2))
  50.           )
  51. ;;; 进行展点
  52.     (setq y1 (read y))
  53.     (setq x1 (read x))
  54.     (setq h1 (read h))
  55.     (setq p1 (list y1 x1 h1)
  56.           p2 (list (+ y1 0.5) (- x1 0.75))
  57.           )
  58.     (command "point" p1)
  59.     (command "text" p2 1 0 e)
  60.     (setq n (1+ n)
  61.           )
  62.     )
  63.   (close fi)
  64.   (command "zoom" "e")
  65. ;;;  (setvar "AutoSnap" 1)
  66.   )
请大家指教.
GMT+8, 2026-11-3 12:12 , Processed in 0.658297 second(s), 32 queries , Gzip On.
