查看: 745|回复: 0
[编程申请]:请问这个LSP中坡度和长度换个位置怎么改?
发表于 2005-3-4 11:45:21 | 显示全部楼层 |阅读模式
默认值 100-4 (管径 - 坡度);
仅输入管径时输入 100,
仅输入坡度时输入 ,5
$XDTB_GLOBAL_SCALE  出图比例默认100
($xdrx_load "xdlsp.lsp")
(if (not $XDTB_GLOBAL_SCALE)
  (setq $XDTB_GLOBAL_SCALE 100.0)
(if (not $XDTB_DMSTRING)
  (setq $XDTB_DMSTRING "100-4")
(defun c:XDTB_DMpipeline (/ oldos tf pt1 pt2 dis str string pmid pt ang1)
  (setq tf t)
  (setq oldos (getvar "osmode"))
  (xdrx_begin)
  (xdrx_ucson)
  (xdrx_sysvar_push "osmode")
  (setvar "osmode" oldos)
  (while tf
    (if        (setq pt1 (getpoint "\n起  点: "))
      (progn
        (setq pt2 (getpoint pt1 "\n终  点: "))
        (setq dis  (rtos (distance pt1 pt2) 2 0);; 长度 0 小数点后位数
              pmid (xdrx_midp pt1 pt2)
              ang1 (angle pt1 pt2)
        (if (> ang1 pi)
          (setq ang1 (- ang1 pi))
        (setq pt (polar        pmid
                        (if (> ang1 _pi2)
                          (- ang1 _pi2)
                          (+ ang1 _pi2)
                        $XDTB_GLOBAL_SCALE
        (prompt (strcat "\n管长 = " dis))
        (setq str
               (getstring (strcat "\n[管径-坡度]<d" $XDTB_DMSTRING ">: ")
        (cond
          ((= (xdrx_string_findoneof str ",") 0)
                  (strcat
                    (car (xdrx_string_tok $XDTB_DMSTRING "-"))
                    (xdrx_string_trimleft str ",")
           (setq
             string (strcat
                      "D"
                      dis
          ((> (xdrx_string_find str ",") 0)
                  (strcat
                    (xdrx_string_trimright str ",")
                    (last (xdrx_string_tok $XDTB_DMSTRING "-"))
           (setq
             string
              (strcat
                "D"
                dis
          ((= str "")
           (setq
             string (strcat "D"
                            (xdrx_string_replace
                              $XDTB_DMSTRING
                              (strcat "-" dis "-")
          (T
            (setq $XDTB_DMSTRING str)
            (setq
              string (strcat "D"
                             (xdrx_string_join
        ;(setvar "osmode" 0)
        (command ".text"
                 "j"
                 "bc"
                 "_non"
                 pt
                 (* 2.5 $XDTB_GLOBAL_SCALE)
                 ($xdlsp_rtd ($xdlsp_angle_format ang1))
                 string
      (setq tf nil)
  (xdrx_sysvar_pop)
  (xdrx_ucsoff)
  (xdrx_end)
  (princ)
输出时它先输长度再到坡度,怎么改LSP,把它们位置换一下。也就是先坡度,然后再长度。
GMT+8, 2026-11-6 07:08 , Processed in 0.367222 second(s), 32 queries , Gzip On.
