查看: 718|回复: 0
浩辰暖通4-Int4的lisp程序3
已领礼包: 6个
发表于 2005-3-10 18:32:22 | 显示全部楼层 |阅读模式
(defun c:fkbj(/ ssEquipment ssWindport ent ssLen i infoList retList strOldType
              strOldSpec strOldModel strOldAirFlow strOldElevation strOldLength strOldWidth strOldHeight
              strOldCircle
              strNewSpec strNewModel strNewAirFlow strNewElevation strNewLength strNewWidth strNewHeight
  (setq oldCmdecho (getvar "cmdecho"))
  (prompt "\n*** 风口编辑 ***")
  (princ "\n请选择要编辑的风口")
  ;选择有扩展数据WINDPORTKIND的块
  (setq ssWindport nil)
  (setq ssEquipment (ssget '((0 . "insert") (-3 ("WINDPORTKIND")))))
  ;取设备类别为"风口"或"风口(扩初)"的块放入ssWindport
  (if ssEquipment
    (progn
      (setq sslen (sslength ssEquipment))
      (setq i 0)
      (while (< i sslen)
        (setq ent (ssname ssEquipment i))
        (setq strWindportKind (gxdata ent "WINDPORTKIND" 0))
        (if (or (= strWindportKind "风口") (= strWindportKind "风口(扩初)"))
          (if ssWindport
            (setq ssWindport (ssadd ent ssWindport))
            (setq ssWindport (ssadd ent))
        (setq i (1+ i))
    );end progn
  );end if ssEquipment
  (if ssWindport
    (progn
      (setq sslen (sslength ssWindport))
      (setq ent (ssname ssWindport 0))
      (setq infoList (GetWindportData ent));得到风口数据
      (setq strOldType                 (nth 0 infoList)        ;类型
            strOldSpec                (nth 1 infoList)        ;规格
            strOldModel                (nth 2 infoList)        ;型号
            strOldAirFlow        (nth 3 infoList)        ;风量
            strOldElevation        (nth 4 infoList)        ;标高
;            strOldSide                (nth 5 infoList)        ;是否侧风口
            strOldCircle        (nth 6 infoList)        ;是否圆风口
;            strOldBlockName        (nth 7 infoList)        ;块名
            strOldLength        (nth 8 infoList)        ;风口长
            strOldWidth                (nth 9 infoList)        ;风口宽
            strOldHeight        (nth 10 infoList)        ;风口高
      (setq i 1)
      (while (< i sslen)
        (setq ent (ssname ssWindport i))
        (if (/= strOldType         (nth 0 infoList))        (setq strOldType ""))
        (if (/= strOldSpec         (nth 1 infoList))        (setq strOldSpec ""))
        (if (/= strOldModel         (nth 2 infoList))        (setq strOldModel ""))
        (if (/= strOldAirFlow         (nth 3 infoList))        (setq strOldAirFlow ""))
        (if (/= strOldElevation (nth 4 infoList))        (setq strOldElevation ""))
        (if (/= strOldCircle         (nth 6 infoList))        (setq strOldCircle ""))
        (if (/= strOldLength         (nth 8 infoList))        (setq strOldLength ""))
        (if (/= strOldWidth         (nth 9 infoList))        (setq strOldWidth ""))
        (if (/= strOldHeight         (nth 10 infoList))        (setq strOldHeight ""))
        (setq i (1+ i))
      (setq RetList (WindPortEdit strOldType strOldSpec strOldModel strOldAirFlow
                      strOldElevation strOldLength strOldWidth strOldHeight strOldCircle)
      (setq ;strNewType                 (nth 0 infoList)        ;类型
            strNewSpec                (nth 1 RetList)                ;规格
            strNewModel                (nth 2 RetList)                ;型号
            strNewAirFlow        (nth 3 RetList)                ;风量
            strNewElevation        (nth 4 RetList)                ;标高
            strNewLength        (nth 5 RetList)                ;风口长
            strNewWidth                (nth 6 RetList)                ;风口宽
            strNewHeight        (nth 7 RetList)        ;风口高
      ;把没修改过的值置为nil
;      (if (= strOldType strNewType)                 (setq strNewType nil))
      (if (= strOldSpec strNewSpec)                 (setq strNewSpec nil))
      (if (= strOldModel strNewModel)                (setq strNewModel nil))
      ;下面的实数字符串转换成实数再转换成字符串是为了精确到2位小数
      (if (or (= strNewAirFlow "")
              (= (rtos (atof strNewAirFlow) 2 2) (rtos (atof strOldAirFlow) 2 2))
        (setq strNewAirFlow nil)
      (if (or (= strNewElevation "")
              (= (rtos (atof strNewElevation) 2 2) (rtos (atof strOldElevation) 2 2))
        (setq strNewElevation nil)
      (if (or (= strNewLength "")
              (= (rtos (atof strNewLength) 2 2) (rtos (atof strOldLength) 2 2))
        (setq strNewLength nil)
      (if (or (= strNewWidth "")
              (= (rtos (atof strNewWidth) 2 2) (rtos (atof strOldWidth) 2 2))
        (setq strNewWidth nil)
      (if (or (= strNewHeight "")
              (= (rtos (atof strNewHeight) 2 2) (rtos (atof strOldHeight) 2 2))
        (setq strNewHeight nil)
      ;修改风口数据
      (setq i 0 sslen (sslength ssWindport))
      (while (< i sslen)
        (setq strWindportKind (gxdata ent "WINDPORTKIND" 0));风口类别
        (SetWindportData ent
          strNewLength strNewWidth strnewHeight strWindportKind)
        (setq i (1+ i))
    );end progn
  );end if ssWindport
  (setvar "cmdecho" oldCmdecho)
;得到风口数据
(defun GetWindportData (ent / entList strType strSpec strModel strAirFlow
                        strSide strCircle strBlockName dXScale dYScale dZScale
                        attList dLength dWidth dHeight dElevation strLength
                        strWidth strHeight strElevation infoList)
  (setq entList (entget ent))
  (setq strType (gxdata ent "TYPE" 0))
  (setq strSpec (gxdata ent "SPECIFICATION" 0))
  (setq strModel (gxdata ent "WINDPORTMODEL" 0))
  (setq strAirFlow (gxdata ent "AIRFLOW" 0))
  (setq strSide (gxdata ent "SIDE" 0))
  (setq strCircle (gxdata ent "CIRCLE" 0))
  (setq strBlockName (cdr (assoc 2 entList)))
  (setq dElevation (/ (nth 3 (assoc 10 entList)) 1000))
  (setq dXScale (cdr (assoc 41 entList)))
  (setq dYScale (cdr (assoc 42 entList)))
  (setq dZScale (cdr (assoc 43 entList)))
  (setq attList (~getval strBlockName));块属性表
  (if attList
    (progn
      (setq dLength (* dXScale (nth 0 attList))
            dWidth  (* dYScale (nth 1 attList))
            dHeight (* dZScale (nth 2 attList))
  (setq strElevation (rtos dElevation 2 2))
  (setq strLength (rtos dLength 2 2))
  (setq strWidth  (rtos dWidth 2 2))
  (setq strHeight (rtos dHeight 2 2))
  (setq infoList (list strType                ;类型
                       strSpec                ;规格
                       strModel                ;型号
                       strAirFlow        ;量
                       strElevation        ;标高
                       strSide                ;是否侧风口
                       strCircle        ;是否圆风口
                       strBlockName        ;块名
                       strLength        ;风口长
                       strWidth                ;风口宽
                       strheight        ;风口高
;设置风口数据
(defun SetWindportData (ent strNewSpec strNewModel strNewAirFlow strNewElevation
                        strNewLength strNewWidth strNewHeight strWindportKind
                        / entList strBlockName dXScale dYScale dZScale attList)
  (if (= strWindportKind "风口(扩初)")
    (progn;如果是扩初风口,修改原来的扩展数据
      (setq f-ll (gxdata ent "F-LL" 1))
      (setq f-cc (gxdata ent "F-CC" 1))
      (if f-ll
        (progn
          (if strNewAirFlow (setq f-ll (list (atof strNewAirFlow) (nth 1 f-ll) (nth 2 f-ll))))
          (if strNewLength  (setq f-ll (list (nth 0 f-ll) (atof strNewLength)  (nth 2 f-ll))))
          (if strNewWidth   (setq f-ll (list (nth 0 f-ll) (nth 1 f-ll)   (atof strNewWidth))))
          (_kzsj1 ent "F-LL" f-ll)
      (if f-cc
        (progn
          (if strNewLength (setq f-cc (list (atof strNewLength) (nth 1 f-cc) (nth 2 f-cc))))
          (if strNewWidth  (setq f-cc (list (nth 0 f-cc) (atof strNewWidth)  (nth 2 f-cc))))
          (if strNewHeight (setq f-cc (list (nth 0 f-cc) (nth 1 f-cc)  (atof strNewHeight))))
          (_kzsj1 ent "F-CC" f-cc)
  );end (if (= strWindportKind "风口(扩初)")
  ;修改新加的扩展数据
  (if strNewSpec         (_kzsj1 ent "SPECIFICATION" strNewSpec))
  (if strNewModel         (_kzsj1 ent "WINDPORTMODEL" strNewModel))
  (if strNewAirFlow        (_kzsj1 ent "AIRFLOW" strNewAirFlow))
  (setq entList (entget ent '("*")))
  ;修改标高(即插入点的Z坐标)
  (if strNewElevation
    (progn
      (setq ptIns (assoc 10 entList))
      (setq ptIns (list (nth 0 ptIns) (nth 1 ptIns) (nth 2 ptIns) (* (atof strNewElevation) 1000)))
      (setq entList (subst ptIns (assoc 10 entList) entList))
  ;修改长宽高
  (if strNewLength
    (progn
      (setq dXScale (/ (atof strNewLength) (nth 0 attList)))
      (setq entList (subst (cons 41 dXScale) (assoc 41 entList) entList))
      (if (= (gxdata ent "CIRCLE" 0) "1");如果是圆风口则长宽一起改
        (setq entList (subst (cons 42 dXScale) (assoc 42 entList) entList))
  (if strNewWidth
    (progn
      (setq dYScale (/ (atof strNewWidth) (nth 1 attList)))
      (setq entList (subst (cons 42 dYScale) (assoc 42 entList) entList))
  (if strNewHeight
    (progn
      (setq dZScale (/ (atof strNewHeight) (nth 2 attList)))
      (setq entList (subst (cons 43 dZScale) (assoc 43 entList) entList))
  ;更新实体
  (entmod entList)
GMT+8, 2026-11-6 00:13 , Processed in 0.402737 second(s), 32 queries , Gzip On.
