查看: 1232|回复: 2
[求助] [求助]:请教!为什么第二段距离及面积值是错的?
发表于 2005-3-12 16:57:06 | 显示全部楼层 |阅读模式
(defun c:test ()
  (if (and (setq pt1 (getpoint "\n起点<退出> : "))
           (setq pt2 (getpoint pt1 "\n下一点<退出> : "))
    (progn
      (setq dist (rtos (distance pt1 pt2) 2 3))
      (command "area" pt1)
      (while (setq pt2 (getpoint pt2 "\n下一点<退出> : "))
        (command pt2)
        (setq dist12 (distance pt1 pt2)
              pt1    pt2
              dist   (strcat dist "+" (rtos dist12 2 3))
  (command)
  (setq dist (strcat dist "=" (rtos (getvar "area") 2 3)))
  (princ dist)
  (princ)
发表于 2005-4-3 10:44:24 | 显示全部楼层
是不是右的点z值不为0啊?!
我也遇到过类似问题,后来发现我点取的点不在一个平面上!
发表于 2005-4-3 11:01:20 | 显示全部楼层
(defun c:test ()
(progn
(while pt2 ;;;此处你重复定义了PT2所以PT2已经跳到第三点去了,故错!!
(command pt2)
pt1 pt2
(command "");;;少""
(princ dist)
(princ)
GMT+8, 2026-11-22 09:55 , Processed in 0.406561 second(s), 14 queries , Gzip On, File On.
