查看: 1659|回复: 7
[LISP函数]:读取字符串中逗号分隔的数据的函数
发表于 2005-3-21 14:18:53 | 显示全部楼层 |阅读模式
(defun rdl (rd)
  (setq i 0 j 1 )
  (while (vl-string-search "," rd i) ;while1
    (set (read (strcat "n" (itoa j) )) (vl-string-search "," rd i))
    (setq i (1+ (vl-string-search "," rd i)))
    (setq j (1+ j))
    );while1
  (setq n0 -1)
  (set (read (strcat "n" (itoa j) )) (strlen rd))
  (setq k j)
  (while (>= k 1) ;while2
    (set (read (strcat "rd" (itoa k)))
         ;(read
           (substr rd (+ 2 (eval (read (strcat "n" (itoa (1- k)) ))))
                       (- (eval (read (strcat "n" (itoa k ))))
                          (eval (read (strcat "n" (itoa (1- k) ))) ) 1)));)
    (setq k (1- k))
    );while2
  );defun
这个函数读取一个字符串,我做的时候是以逗号为分隔的,如果以别的符号分隔的话自己可以改下了用
例:
(setq a1 "111,256,236,55566")
(rdl a1)
则RD1为111,RD2为256,RD3为236,RD4为55566,RDN为第N个数据
这个函数的好处是事先不指定N就可以读取,需要第几个数据调用RDN就是了
读文件的时候特别有用。
发表于 2005-3-21 16:59:16 | 显示全部楼层
果然山外有山,人外有人。高手
果然山外有山,人外有人。高手
发表于 2005-3-21 17:28:19 | 显示全部楼层
在CAD14下怎么出现下面错误?
Command: (rdl a1)
error: null function
(VL-STRING-SEARCH "," RD I)
(WHILE (VL-STRING-SEARCH "," RD I) (SET (READ (STRCAT "n" (ITOA J)))
(VL-STRING-SEARCH "," RD I)) (SETQ I (1+ (VL-STRING-SEARCH "," RD I))) (SETQ J
(1+ J)))
(RDL A1)
*Cancel*
 楼主| 发表于 2005-3-21 18:27:36 | 显示全部楼层
VL函数在R14里面是没有的。
发表于 2005-3-22 14:51:56 | 显示全部楼层
解决了我在论坛中提出的如何取得不含空格的字符串问题!
发表于 2005-3-22 17:43:04 | 显示全部楼层
更短的程序
测试:
(setq str "2131,33,22")
(tt "2131,33,22") -> (2131 33 22)
(mapcar 'print (list dl1 dl2 dl3))
[php]
(defun tt (str / i)
  (while (vl-string-search "," (setq str (vl-string-subst " " "," str))))
  (setq i 0)
  (mapcar '(lambda(x)(set (read(strcat "dl" (itoa(setq i (1+ i))))) x)) (read(strcat "(" str ")"))
)[/php]
发表于 2005-3-22 19:23:54 | 显示全部楼层
陌生人 好久不见了。
已领礼包: 221个
发表于 2013-8-11 09:27:13 | 显示全部楼层
终于找到了我要的程序,谢谢分享:)
GMT+8, 2026-10-17 04:09 , Processed in 0.894575 second(s), 46 queries , Gzip On.
