查看: 854|回复: 0
[LISP程序]:如何调用Delphi编写的DLL?调试通不过
发表于 2005-3-31 13:06:59 | 显示全部楼层 |阅读模式
不好意思,涉及多个概念,在VBA版也发了一份
使用VisualLISP调用Delphi编写的DLL,调试通不过
生成DLL完整的Delphi代码,生成的DLL文件名为MyDll.dll
library MyDll;  // library 为 DLL
uses
  SysUtils,Classes;
function AddOne(i:integer):integer;stdcall;  // 一般需要导出的函数都要是 stdcall
begin
  Result:=i+1;
end;
exports   // 导出表
  AddOne;
begin
end.
调用DLL的LISP代码
(vl-load-com)
(defun c:testdll (/ a re)
  (setq a (vla-getinterfaceobject
     (vlax-get-acad-object)
     "MyDll"   ;1、这里肯定有问题!!!
   )                             ;   Delphi没有类模块,对照VB不知该怎么改动
  (setq re (vlax-invoke-method          ;2、是不是这样获得返回值?
      a
      "AddOne"
      100                        ;3、是不是这样传递参数?
  (vlax-release-object a)
  (princ re)
  (princ)
运行提示      错误: Automation 错误。 加载应用程序时出现问题
附VBA帮助中关于GetInterfaceObject说明
Accepts a program ID and attempts to load it into AutoCAD as an in-process server.
RetVal = object.GetInterfaceObject(ProgID)
Object
Application
The object or objects this method applies to.
ProgID
String; input-only
The program ID of the interface object to return.
RetVal
Object
The interface object matching the program ID.
Example中ProgID给了个令人摸不着头脑的例子
Dim poly As Object
    Set poly = ThisDrawing.Application.GetInterfaceObject("Polycad.Application")
GMT+8, 2026-11-6 05:13 , Processed in 0.464380 second(s), 32 queries , Gzip On.
