查看: 2712|回复: 15
[LISP函数]:强有力的颜色过滤器..
发表于 2005-4-9 15:40:45 | 显示全部楼层 |阅读模式
[PHP]
(defun hy_leachcolorlist(en / eno color layer ccolor cord_laye layerlist
             layerlist1 layername layercolor needlis);;;;參照物體顏色?/font>^濾表
(SETQ  needlis NIL)
  (if (= (type en) 'ENAME)
  (progn
  (setq eno (vlax-ename->vla-object en))
  (setq color (vla-get-color eno))
  (setq layer (vla-get-layer eno))
  (setq ccolor (cdr(assoc 62 (entget(tblobjname "layer" layer)))))
  (setq cord_layer (tblnext "layer" t))
  (setq layerlist nil layerlist1 nil)
  (while cord_layer
    (setq layername (cdr(assoc 2 cord_layer)))
    (setq layercolor (cdr(assoc 62 cord_layer)))
    (if (= layercolor color)(setq layerlist (cons (cons 8 layername) layerlist)))
    (if (= layercolor ccolor)(setq layerlist1 (cons (cons 8 layername) layerlist1)))
    (setq cord_layer (tblnext "layer"))
  (if (/= color 256)
      (setq needlis (append '((-4 . "<or"))
            (list(cons 62 color))
            '((-4 . "<and")(62 . 256)(-4 . "<or"))
            (append layerlist  (list(cons 62 color)) )
            '((-4 . "or>")(-4 . "and>")(-4 . "or>"))))
                    (list '(-4 . "<and")(cons 8 layer)'(62 . 256)'(-4 . "and>"))
                 (list(cons 62 ccolor))
                layerlist1
  (if (= (type en) 'INT) (progn
  (setq color EN)
  (setq layerlist nil)
  (while cord_layer
  (if (/= color 256)
  needlis
[/PHP]
需要建立以参照物的颜色选择集过滤
(SSGET (hy_leachcolorlist(CAR(ENTSEL "\n请选择参照物:"))))
需要建立以2#色选择集过滤
(SSGET (hy_leachcolorlist 2))
只要颜色一样不管是否随层全部选中
发表于 2005-4-9 22:43:33 | 显示全部楼层
经测试,程序可用,但仍有一点小小小的问题需改善:
1,当只有图层0而无其它图层时,程序出错:
Command: ec
请选择参照物:erase
Select objects:
Command: EC Unknown command "EC".  Press F1 for help.
Command: nil
2,当只有0层有物体时而其它图层为空时,仍提示上列错误,但如在其它层上加一根线,程序通过
应该不是我在你的程序前加上调用命令及删除记忆中的色#导致上列问题吧???
(defun c:ec ()
(setq s(SSGET (hy_leachcolorlist(CAR(ENTSEL "\n请选择参照物:")))))
(command "erase" s "")
             layerlist1 layername layercolor needlis)..........
 楼主| 发表于 2005-4-10 10:15:09 | 显示全部楼层
呵呵..是有这种情况..没有考虑到
是一个BUG,,现在改好了...试一下
发表于 2005-4-10 21:54:11 | 显示全部楼层
嗯,现在真够强的啦
发表于 2005-4-10 23:09:31 | 显示全部楼层
不用or,用逗号分割要好些
发表于 2005-4-12 15:25:56 | 显示全部楼层
不好用啊。
 楼主| 发表于 2005-4-12 15:58:52 | 显示全部楼层
如果你是2000以下的版本就不好用..
如果不是的话就可以用...看看你有没有加载错误
发表于 2005-4-14 00:24:19 | 显示全部楼层
程序经测试,仍有需要改良的地方:
如果参照物體顏色为bylayer,那将删除所选物体为bylayer的颜色全部选中。。。
程序应该分析参照物为随层,就查询相应层的信息,得到本来的颜色来定义之?!
 楼主| 发表于 2005-4-14 11:18:39 | 显示全部楼层
我再看看...
经过我的测试也不存在你所说的
情况啊?我的过滤方法是:
只要颜色一致不管是否随层全部可以
被选中...
注意"只要是颜色一致"..
也就是说你参照物是什么颜色(如果为随层就为
该层的颜色)
就可以选择此颜色
的所有物体包括随层的物体(随层的颜色是和参照物
颜色一致)
发表于 2005-4-14 17:09:41 | 显示全部楼层
Re: [LISP函数]:强有力的颜色过滤器..
最初由 舟自横 发布
[B][PHP]
  (pr... [/B]
加载后,不能使用啊.能否做一个完整的程序.期待之中
 楼主| 发表于 2005-4-14 20:36:22 | 显示全部楼层
[PHP]
不会吧这个这么简单还要写吗?
(DEFUN C:ESCOLOR(/ FILTER SS KEYWORD )
  (SETQ FILTER  (hy_leachcolorlist (CAR(ENTSEL "\n请选择颜色参照物体.."))))
  (PROMPT "\n请选择需要操作的物体..")
  (SETQ SS (SSGET FILTER))
  (INITGET "1 2 3 ")
(SETQ KEYWORD (GETKWORD "\n删除(1),复制(2),移动(3)..(1?)"))
(IF (=  KEYWORD NIL) (SETQ KEYWORD  "1"))
(COND ((= KEYWORD  "1") (SETQ CMD "._ERASE"))
             ((= KEYWORD  "2") (SETQ CMD "._COPY"))
             ((= KEYWORD  "3") (SETQ CMD "._MOVE"))
(IF (NOT(=  KEYWORD  "1") )
    (COMMAND CMD SS "" PAUSE)
    (COMMAND CMD SS "" ))
(PRIN1)
和上面的子程序一起加载就可以了.
[/PHP]
发表于 2005-4-15 00:26:10 | 显示全部楼层
不实用
发表于 2005-4-19 00:01:02 | 显示全部楼层
最初由 啵浪鼓 发布
[B]程序经测试,仍有需要改良的地方:
程序应该分析参照物为随层,就查询相应层的信息,得到本来的颜色来定义之?! [/B]
难怪我会出现上面的错误了,仔细验证后,原来是在选参照物时没有选择到物体,(而信息栏中无任何提示是否选择到物体)也就是此时参照物为空,如果再选择物体而导致选中所有了。
楼主应该加上提示参照物是否有选择到,如果没选择到应设置继续选择或是平静退出。(如果是选择平静退出不要出现任何出错的信息,现在好怕那种出错退出的字眼~!好像lisp还没有平静退出的程序)
所以在程序前言中加写一段不选中继续选之。。。不知可好?
(while (not (SETQ FILTER (hy_leachcolorlist (CAR(ENTSEL "\n请选择颜色参照物体..")))))
   (princ)
   (setq FILTER nil)
 楼主| 发表于 2005-4-19 09:00:59 | 显示全部楼层
这样不是很好..当你选择错误时还是会错..
(SETQ FILTER (hy_leachcolorlist (CAR(ENTSEL "\n参照物不存在,请重新选择颜色参照物体.."))))
发表于 2005-4-19 12:51:20 | 显示全部楼层
(while(not (or(setq el (entsel))
(if el (progn ...)
    nil
给个框架,自己填空.
实现:1,选中物体,跳出
   2,没有选中,循环
   3,回车,跳出.
GMT+8, 2026-11-6 07:02 , Processed in 0.610276 second(s), 60 queries , Gzip On.
