查看: 801|回复: 3
[分享]:autoplant设备复用
发表于 2005-4-13 12:23:40 | 显示全部楼层 |阅读模式
How can I copy Equipment from an existing model to the current model?
Solution:
Type XREF within the current AutoPLANT Equipment drawing. Attach the existing drawing.
Type XREF at the command line to Bind (Insert Type) the XREF drawing.
Explode the Bound XREF drawing.
Select the "Equipment > Database Tools > Repair Database" pulldown. This will add the inserted Equipment into the current model and database.
 楼主| 发表于 2005-4-15 08:15:58 | 显示全部楼层
我试了一下,炸不开,用不了,那位老大有砧板的培训教程呀,能提供一下不
发表于 2005-4-15 16:37:40 | 显示全部楼层
即使楼主的方法可行,也是导出全部设备数据,无法选择。
看来有必要二次开发设备导出功能。
 楼主| 发表于 2005-4-16 15:42:26 | 显示全部楼层
不知道 利用宏行不行
GMT+8, 2026-11-3 07:15 , Processed in 0.426684 second(s), 38 queries , Gzip On.
