查看: 889|回复: 5
[求助] .....................................
发表于 2005-5-4 23:10:16 | 显示全部楼层 |阅读模式
发表于 2005-5-5 13:16:39 | 显示全部楼层
[php]
(load "xyp_lib")                        ;加载通用函数
如果已经下载xyp_lib并放到搜索路径下可以不再下载!
利用以下任何一种方式即可加载和运行通用函数内的所有子程序:
1.在每个程序内增加(load"xyp_lib")
2.在acad.lsp中增加(load"xyp_lib")
3.在command下,输入(load"xyp_lib")
4.在菜单.mnl中增加(load"xyp_lib")
通用函数下载地址:http://www.xdcad.net/forum/showthread.php?s=&threadid=325268
;;;文字改序列
(defun c:test ()
  (cmdla0)
  (setq        no1 (ureal 1 "" "\n初始值" no1)
        nv  (- no1 1)
  (while (setq s1 (entsel "\n选择文本: "))
    (setq s1 (car s1)
          nv (+ nv 1)
          txt (rtos nv 2)
    (sub_upd s1 1 txt)
  (cmdla1)
[/php]
 楼主| 发表于 2005-5-5 19:32:36 | 显示全部楼层
发表于 2005-5-6 09:30:23 | 显示全部楼层 |阅读模式
[php]
;;;文字改序列
(defun c:test ()
        nv  (- no1 1))
    (setq s1  (car s1)
          nv  (+ nv 1)
          txt (rtos nv 2))
    (sub_upd s1 1 txt)))
(defun ureal (bit kwd msg def / inp)
  (if def
    (setq msg (strcat "\n" msg "<" (rtos def 2) ">: ")
          bit (* 2 (fix (/ bit 2))))
    (setq msg (strcat "\n" msg ": ")))
  (initget bit kwd)
  (setq inp (getreal msg))
  (if inp inp def))
(defun sub_upd (ename code new-value)
  (setq        cc (subst (cons code new-value)
                  (assoc code (entget ename))
                  (entget ename)))
  (entmod cc)
  (entupd ename))
[/php]
 楼主| 发表于 2005-5-6 11:27:24 | 显示全部楼层
发表于 2005-5-6 12:33:50 | 显示全部楼层
[php]
;;;文字改序列
(defun c:test ()
  (setq no1 (ureal 1 "" "\n初始值" 1) nv (- no1 1))
  (while (setq s1 (entsel "\n选择文本<退出> : "))
    (if (or(= (dxf 0 (entget(car s1)))"TEXT")(= (dxf 0 (entget(car s1)))"MTEXT"))
        (progn (setq s1  (car s1)nv  (+ nv 1)txt (rtos nv 2))(sub_upd s1 1 txt)))))
  (if def
    (setq msg (strcat "\n" msg "<" (rtos def 2) ">: ")bit (* 2 (fix (/ bit 2))))
  (initget bit kwd)
  (if inp inp def))
  (setq cc (subst (cons code new-value)(assoc code (entget ename))(entget ename)))
  (entmod cc)
  (entupd ename))
(defun dxf (code elist) (cdr (assoc code elist)))
[/php]
GMT+8, 2026-11-6 08:13 , Processed in 0.464851 second(s), 44 queries , Gzip On.
