查看: 2028|回复: 5
[LISP程序]:粗糙度标注程序
发表于 2003-3-8 19:45:56 | 显示全部楼层 |阅读模式
下面一个小程序可用于标注粗糙度,很方便,有兴趣的可以试试
  1. (defun c:ccd(/ cly size box os sc lg pp1 pp2 ag0 ag1 s r g30 value dx ang)
  2.       (setvar "cmdecho" 0)
  3.       (setq cly (getvar "clayer"))
  4.       (setvar "clayer" "3")
  5.       (setq size (getvar "textsize"))
  6.       (setq sc (getvar "dimscale"))
  7.       (setq os (getvar "osmode"))
  8.       (setvar "osmode" 0)
  9.      ;;; (setq box (getvar "pickbox"))
  10.       (setvar "pickbox" 10)
  11.       (setq g30 (/ pi 6) dx (* sc 4.5) r (/ dx (* 2 (sqrt 3.0))))
  12.       (setq lg true)
  13.       (while (not lg)
  14.         (setq pp1 (getpoint "\n在要标注粗糙度的轮廓线外侧指定一点:"))
  15.         (setq lg (setq pp2 (osnap pp1 "nearest")))
  16.         (setq ag0 (angle pp2 pp1))
  17.         (setq s (getint "\n请选一种标注符号: 1.加工面 2.非加工面:<1>:"))
  18.         (setq value (getstring "\n粗糙度值:"))
  19.         (command "line" (polar pp2 (+ ag0 g30) dx)  pp2 (polar pp2 (- ag0 g30) (* 2 dx)) "")
  20.           (if (= s 2)
  21.               (command "circle" (polar pp2 ag0 (* 2 r)) r)
  22.               (command "line" (polar pp2 (+ ag0 g30) dx) (polar pp2 (- ag0 g30) dx) "")
  23.           )
  24.           (if (and (> ag0 0) (<= ag0 pi))
  25.              (setq ang (+ ag0 pi))
  26.              (setq ang ag0)
  27.           )
  28.           (setq ang (+ ang (* 0.5 pi)))
  29.           (command "text" "j" "m" (polar pp2 ag0 (* dx 0.8 (sqrt 3.0)))
  30.                (* dx 0.5) (/ (* 180 ang) pi) value)
  31.           (command "text" pp2  size 0 ".")
  32.           (command "erase" "l" "")
  33.           (setvar "clayer" cly)
  34.         (setvar "cmdecho" 1)
  35.         (setvar "pickbox" 3)
  36.         (setvar "osmode" os)
  37.         )
  38.         )
发表于 2006-8-9 16:32:05 | 显示全部楼层
另一种思路的方法.不过,键盘输入太多啦.
发表于 2006-10-27 18:19:06 | 显示全部楼层
免的畫來畫去,還是用lisp比較好
发表于 2006-10-28 09:28:23 | 显示全部楼层
虽然不画机械装配图,但还是谢谢啦,收下了.
发表于 2006-10-31 12:33:54 | 显示全部楼层
谢谢啦,我正需要
发表于 2007-2-14 13:37:09 | 显示全部楼层
谢谢,原程序可以研究吗
GMT+8, 2026-11-3 00:53 , Processed in 0.454095 second(s), 42 queries , Gzip On.
