查看: 415|回复: 0
[求助]:求助 麻烦个位大虾帮帮忙 谢谢!
发表于 2005-5-23 09:06:52 | 显示全部楼层 |阅读模式
(setq txt1 "3000")
(defun editdim ()
   (princ "\n选择需修改的标注 :")
   (setq p (ssget))
   (command "dimedit" "n" dim2 "p" "")
   (setvar "cmdecho" 1)
(defun editdimh ()
   (setq p (ssget))
   (command "dimedit" "h" "p" "")
(defun c:de (/ dim1 p dim2)
(setvar "cmdecho" 0)
(princ "\n请输入标注字符,允许汉字和空格。(空格->还原)(空回车->缺省值)<")
(princ txt1)
(setq dim1 (getstring T ">:"))
(cond
      ((= dim1 " ")(editdim))
      ((= dim1 "")(setq dim2 txt1)(editdim))
      ((= dim1 "H")(editdimh))
      ((setq txt1 dim1)(setq dim2 dim1)(editdim))
麻烦大虾帮我修改一下,结果是可以随意的修改8字的尺寸,谢谢!*-*4
GMT+8, 2026-8-7 05:24 , Processed in 0.431532 second(s), 31 queries , Gzip On.
