查看: 860|回复: 0
[求助] [求助]:能把单行文字加法变成单行j多行文字的加和乘么
发表于 2005-5-26 12:26:26 | 显示全部楼层 |阅读模式
(defun c:accum(/ a n un index e1 e num tol)
(setq a (ssget) tol 1)
(setq n (sslength a))
(setq un (getvar "luprec"))
(setvar "luprec" 8)
(setq index (- n 1))
(repeat n
(setq e1 (entget (ssname a index)) index (1- index))
(setq e (assoc 0 e1))
(if(= "TEXT" (cdr e))
(progn
(setq num (atof (cdr (assoc 1 e1))))
(setq tol (* tol num))
(princ (strcat " 总数是 " (rtos tol)))
(setvar "luprec" un)
(princ)
(defun c:sum(/ a n un index e1 e num tol)
(setq a (ssget) tol 0.0)
(setvar "luprec" 8)
(repeat n
(progn
(setq tol (+ tol num))
; (alert (strcat " 总数是 " (rtos tol)))
(princ)
此程序只适合单行文字加和乘
能把单行文字加法变成单行和多行文字的加和乘么
GMT+8, 2026-11-6 09:03 , Processed in 0.562518 second(s), 31 queries , Gzip On.
